SolaraGuy.com • View topic - Aiming/Adjusting lights on Aftermarket Headlights
Postby FLASH » Tue Oct 25, 2005 9:48 pm
I installed my blackhousing headlights today and expected to need to readjust them. It seems I just can't get them to how my stock ones look.
No matter how often I turn the High/Low bolt, my passenger side won't go AS HIGH as I'd like it, and I can't get my driver's side to go left very much.
Right now they are both kinda pointing towards my grille and a little low...so I know I won't be blinding anyone but I can't see all that great...
Anyone else have similiar problems with the black housed headlights? And any suggestions what to do?
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Re: Aiming/Adjusting lights on Aftermarket Headlights
Postby Vampire » Tue Oct 25, 2005 10:21 pm
I installed mine for the Gen 1.5 and I have a problem where they aim a little high and outwards. Go figure. I know it doesn't help you but just wanted to let the Gen 1.5 guys know. I haven't tried to adjust them yet but I may need to enlarge some holes ...
FLASH wrote:I installed my blackhousing headlights today and expected to need to readjust them. It seems I just can't get them to how my stock ones look.
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby Jon11582 » Wed Oct 26, 2005 10:05 am
Ill let you know tonight if its not raining up north here...and I dont get lazy.
2000 Black Solara SE
Jon11582
Postby Astro » Wed Oct 26, 2005 10:06 am
Mine was pointed on the ground, but I did get them adjusted ok. It took awhile, I think you have to turn the bolt slowly. It seems when I did it fast, it didn't move at all. I don't know though, I want to raise mine up a bit more. Unfortunately, I haven't had my car in a few weeks, it's sitting at UPFD. :(
Postby ICrazyChrisI » Wed Oct 26, 2005 2:48 pm
If you think visability w/ aftermarket reflectors is bad, just wait till someone makes aftermarket projectors...
ICrazyChrisI
Postby rnsmelody » Wed Oct 26, 2005 2:59 pm
yea i have the same problem too.. sucks. but what do you expect they arnt the best.. i wish the corners would of been better..
rnsmelody
Postby SpikedMantis » Wed Oct 26, 2005 3:01 pm
Geez, this thread is making me feel kind of glad I didn't buy them with everyone else.
SpikedMantis
Postby WTF?? » Wed Oct 26, 2005 4:36 pm
SpikedMantis wrote:Geez, this thread is making me feel kind of glad I didn't buy them with everyone else.
YUUUUUUUUUP!!!! I saved my money!! :D
Retired... its been fun Image
WTF??
Postby Jon11582 » Wed Oct 26, 2005 6:59 pm
OK well I put them on. The headlight quality seems OEM, and so does the reflector pattern inside the lens. The only physical difference I see to OEM (besides the housing color) is that the up-down knob is a 10mm isntead of an 8mm.
I cant get my driverside to the left much either...for some reason when I turn the knob for left-right, it seems to go higher and more out of focus instead of to the left
I cant get a good grip on that screw, so I'll take them out this weekend and try it again with the housing unmounted. I was able to get stock height though using a combination of the up-down screw and the left-right screw (that seems to be moving up), and its still going up more, I had to bring it back down. Visibility isnt bad, but the beam pattern is off a bit off..theres about 3 hotspots and theres 3 streaks coming down from each headlight when i shine up on a wall. Come to think of it, my bulb might not be seated right if its moving up-down instead of side to side and I'm getting hotspots.
I check my bulb seatment later this week. (I got HIDs, dont know if beam pattern will be any different for the halogen people)
Jon11582
Postby Solorange » Wed Oct 26, 2005 9:12 pm
How do you guys know how to aim them properly?
Postby WTF?? » Wed Oct 26, 2005 9:33 pm
Solorange wrote:How do you guys know how to aim them properly?
shine ur lights against a wall or garage... give about 15-20 feet
WTF??
Postby FLASH » Thu Oct 27, 2005 11:03 am
My beam pattern is blotchy. And it looks like they are beams, my OEM lights were greatly dispersed and just gave off this great light, where this light looks like a really focused beam.
Also my passenger side won't go up any more, and if i jiggle the bulb plug (when it's securely attached in the lamp), the chrome part of the housing is MOVING, as if its dettached.
Not very happy with much besides the overall look...
==FLASH==
FLASH
Postby WTF?? » Thu Oct 27, 2005 12:52 pm
Wow.... I wonder who's gunna be first to put these up for sale USED hahahha... seems like itll be VERY SOON!!!!!!!!!!!
WTF??
Postby Jon11582 » Thu Oct 27, 2005 12:54 pm
FLASH wrote:My beam pattern is blotchy. And it looks like they are beams, my OEM lights were greatly dispersed and just gave off this great light, where this light looks like a really focused beam.
Hmmm mine doesnt jiggle when I wiggle the bulb. Does one do it and not the other?
Maybe you broke something? Take it out and shake it and see if your hear anything loose
I still cant figure out how these aiming bolts work physically. Does it tilt chrome part on the inside? If so, maybe you broke something that connects to those bolts that was holding up the inner housing.
I am getting the weird beam patterns though.Surprising since the reflector pattern looks completely OEM.
Jon11582
Postby ICrazyChrisI » Thu Oct 27, 2005 2:58 pm
Probably because they didn't do enough R&D as much as Toyota did.
ICrazyChrisI
