SolaraGuy.com • View topic - LED light for OEM security system
Postby mlimin » Thu Jan 02, 2003 1:32 pm
Anyone know which cable of the oem alarm give out signal to the security light in the speedometer?????????
I try to hook up a led light like those aftermarket alarm.
mlimin
Postby Guest » Fri Jan 03, 2003 9:56 am
the light in your speedo is for your engine disable. it works with that transponder chip in your key. it doesn't have anything to do with an alarm.
you could get a flashing led from radio shack and hook it up to a hot wire.
Guest
Postby krook » Fri Jan 03, 2003 1:10 pm
maybe you could hook up the led to the ignition instead of piggybacking it on your factory oem. do you have a security light that flashes in the car? besides the one on the speedo?
krook
Postby mlimin » Sun Jan 05, 2003 12:33 am
yeahhh, I have that flashing red light. hmmm.. Is that light produce constant electric????anyone know how should I hook up every thing. I really don't have anyclue about the relay wiring.
Thanks
mlimin
Postby krook » Sun Jan 05, 2003 4:54 am
i would say just hook the led up to ignition. does the led have 3 wires coming out of a circuit board, or is it just two?
krook
Postby mlimin » Sun Jan 05, 2003 7:54 pm
it's only have 2 wire coming out. Red and black?? do you know what are the color of ignition switch cable I have to connect??
Thanks
mlimin
