Injen = bad mileage?
I recently got my injen SRI installed and I think that my car is using up more gasoline is this possible or is it all in my head?
- ~Spadwaller~
- SolaraGuy Street Racer
Somedude wrote:actually, adding aftermarket intake will get you better gas milage and more horsepower at the same time. All that restriction with the stock intake system kills power.
hope this helps
Mole wrote:Somedude wrote:actually, adding aftermarket intake will get you better gas milage and more horsepower at the same time. All that restriction with the stock intake system kills power.
hope this helps
I disagree.
More air movent is beneficial if you want hp/trq gains, TRUE.
However the more power, the more gas is used.
The best gas efficiency you can get, is to remain stock and do basic maintenance.
Somedude wrote:Mole wrote:Somedude wrote:actually, adding aftermarket intake will get you better gas milage and more horsepower at the same time. All that restriction with the stock intake system kills power.
hope this helps
I disagree.
Think about this, most stock intake/exhaust system are restrictive. The more restrictive it is, the more effort the engine has to put in order to make it work. You put in a less restrictive system, there will be less mechanical inertia therefore more gas is saved and more power is produced.
~Spadwaller~ wrote:I'm putting the stock back on and only using the injen for dyno-tunes and meets
