SolaraGuy.com • View topic - Underglow question
Underglow question
Underglow question
Postby solow1605 » Fri Nov 11, 2005 7:28 pm
This is mostlly for solara guys' with underglow but anyways i'm getting mine installed tomorrow and i was wondering how much of a pain it is getting my car lowered after i put on the neons. Also where should i get the underglow mounted? (I have a trd kit too)
2003 Anniversary Edition z06. Black on black...seeexxy
solow1605
Postby trdkamuri51o » Fri Nov 11, 2005 7:33 pm
near the kit so that way u can screw them up at the same time :)
lol mount them near the kit seriously... you will have to jack up from your frame from that point on just to be sure not to hit them...
trdkamuri51o
Postby solara86 » Fri Nov 11, 2005 11:23 pm
u have to be very careful when u drive because i had two sets and i broke them over speed bumps it looks good an all but driving slowly and going over every bump carefully is kinda of a hassle but take pics
solara86
Postby trdkamuri51o » Fri Nov 11, 2005 11:28 pm
just make sure they fit and sit higher than the framerails and you will be fine..
if they go below they can crack on speedbumps
make sure the rear is under the bumper a bit
or on the support not near the exhaust
trdkamuri51o
Postby Akfahad » Sat Nov 12, 2005 4:42 am
Did you do a search? I could've sworn this was address'd with pictures? I haven't had a problem with mine. The side tubes I drilled into the frame where you put the jack onto. As for the front, I put behind the plastic splash guard and rear, I undid one of the quick fastener's for the bumper and slide the tube under that. Oh, and make sure you have a lot of zip ties to tie up all the wiring, unless you have something else in mind.
