SolaraGuy.com • View topic - Spec 2+, Fidanza install recommendations
Postby hskrsolara » Thu Nov 17, 2005 3:39 pm
Well, the solara will finally be back up and running after next week. I invested in a Spec stage 2+ clutch with the Fidanza flywheel from horsepower freaks. They were really good to deal with and matched the cheapest price I found on the web.
At first, I was going to go with the act, but after speaking with about 5 different retailers, I decided the spec was the more reputable brand. I was going to go with the spec stage 3, but was told that the 2+ will suit me just fine and will be more comfortable. (the stage 3 was actually cheaper than the 2+ and only had a torque rating of 30 ft*lbs greater than the 2+, but the daily drivability aspect pushed me to go with the 2+, plus I don't race much anyways with my heavy system in). Torque rating of the 2+ is 455 ft*lbs, so it will be more than enough, even if I do get a charger. :)
I am having a local transmission shop back at home do the install. They estimated between $300 and $400 for the complete install of the clutch and flywheel (teardown and rebuild will probably take 8 hours?). Is there anything I should be aware of or any recommendations with the install? The shop that is doing it is real good and very reputable in Nebraska, but they don't do many imports. I know some of you guys have some good transmission experience, and any help would be awesome! Thx.
hskrsolara
Postby Mandarinsolara » Thu Nov 17, 2005 4:09 pm
from experience... ACT sucks, good job
Mandarinsolara
Postby Deion » Thu Nov 17, 2005 4:53 pm
Mandarinsolara wrote:from experience... ACT sucks, good job
I'm still looking at different clutch kits.
What's wrong with the ACT kits?
KV85 wires, Injen w/ extension, X-stream K&N
Clear corners, titanium bulbs, silverstar head/fog lights
Magnum drilled rotors, G-Stop stainless steel lines, CM lowering springs, TRD RSB
Deion
Postby SC V6 » Thu Nov 17, 2005 5:49 pm
I got a spec stage three and love it.. although its a bit harder to drive... little room to let it slip... its good tho...
SC V6
Postby hskrsolara » Thu Nov 17, 2005 8:57 pm
The main thing I was told about the act lineup was that they tend to shake quite a bit and are real jumpy at start-up, with a low durability? Maybe someone with an act can disprove this, but I haven't heard anything bad about the spec's, so that is how I made my choice.
hskrsolara
Postby hskrsolara » Sat Nov 19, 2005 5:23 pm
Any other info fellas (and ladies)?
hskrsolara
