SolaraGuy.com • View topic - TRD RSB knockin'.....
Postby SleeperSolara » Sat Dec 03, 2005 9:35 pm
Well i checked the RSB lube, it wasn't that.
Well i re-lubed it wit alot.
Well i know the rods that bolt on to the RSB is tight.
All the bolts are tight as they can be.
What could it be??????
Postby WTF?? » Sat Dec 03, 2005 10:11 pm
was the rsb new when you bought it?
ensure throughout where the rsb sits that it is not near anything (within a finger gap) that could potentially cause it to hit against and make a knocking noise.
also, are you SURE its the rsb?
Retired... its been fun Image
WTF??
Postby BradOwens » Sun Dec 04, 2005 8:37 am
WTF?? wrote:was the rsb new when you bought it?
what he said. r u sure something else isnt sliding around?
BradOwens
Postby jazzlara » Sun Dec 04, 2005 1:35 pm
my box in the trunk slides and i tend to believe it to be my RSB as well...but its not, the subs are far from secure.
jazzlara
Postby geminimouse » Sun Dec 04, 2005 5:28 pm
probably ur strut mounts
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby SleeperSolara » Mon Dec 05, 2005 8:44 am
I bought it new also.
I'm postivie man it the RSB.
I bolted everything down tight, like nothin' will budge
No i have nothin' in my trunk except for some gloves, and a bag of towels, and sunshades.
The jack is tight and th spare wheel is tighten.
geminimouse wrote:probably ur strut mounts
My sturts, i don't know about that......
Postby Grazi07 » Mon Dec 05, 2005 9:04 am
Bushings.... how about them?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby geminimouse » Mon Dec 05, 2005 1:16 pm
knocking sounds while goin over bumps..usually strut mounts goin bad..
08 Accord Coupe
geminimouse
check your sway bar links
Postby ~SolaRaSpeed~ » Mon Dec 05, 2005 2:25 pm
I just had the same problem recently, my drivers side sway bar link went out. I thought it was one of my rear strut mounts at first as well until I got my car up on a lift and directly pushed up on the link and heard the same knocking sound that I had been hearing when going over bumpy sections of road.
~SolaRaSpeed~
Postby SleeperSolara » Mon Dec 05, 2005 11:25 pm
Problem solved.....
Had to wait for the grease to work it way in the bushin's.
Postby Vampire » Mon Dec 05, 2005 11:32 pm
Really? I would think the bushings would squeak not make a knocking sound. Well, it's solved so who cares right?
SleeperSolara wrote:Problem solved.....
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby SleeperSolara » Tue Dec 06, 2005 8:11 am
Vampire wrote:Really? I would think the bushings would squeak not make a knocking sound. Well, it's solved so who cares right?
I really don't know.
Just yesterday it finally stopped, though.
So yeah problem solved.
Users browsing this forum: No registered users and 106 guests
