SolaraGuy.com • View topic - Baking clear corners
Postby RichD978 » Thu Dec 08, 2005 6:21 am
Along with doing my own black housing headlights. I found a way to make really clean black clear corners.. However, I looked up the DIY clear corner method
http://www.solaraguy.org/viewtopic.php?t=4726
but it just says to pry it open. I tried that the first time and cracked one of them. What temp can I put these in the oven and bake it...just to get the sealant to melt a little. Temp and amount of Time that is. Look forward to your answers. Thanks
RichD978
Postby CrimsonDawn » Thu Dec 08, 2005 6:34 am
You should try using a heat gun, I used it for my head lights instead of an oven, I thought it was safer, faster and easier to work with than an oven. Thats just my opinion, but good luck with your project.
CrimsonDawn
Postby xavier » Thu Dec 08, 2005 7:10 am
I tried the bake method on my clears and it melted the actual plastic causing the lens to warp... Id be careful
xavier
Postby FLASH » Thu Dec 08, 2005 7:15 am
I did the headlights at about 250, and since they are half the size of the headlights, id bake them at about 100. Also, I wouldnt pre-heat the oven
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Solorange » Thu Dec 08, 2005 5:52 pm
I know these are different than the ones that come with the black lights on ebay. But this may help you out and make your project less of a headache. Check these out and see if you can live with these.
http://cgi.ebay.com/ebaymotors/98-01-99 ... enameZWDVW
Postby RichD978 » Thu Dec 08, 2005 6:11 pm
Solorange wrote:I know these are different than the ones that come with the black lights on ebay. But this may help you out and make your project less of a headache. Check these out and see if you can live with these.
i seen those and they are ugly IMO. I want OEM quality and good looks
RichD978
Postby Solorange » Fri Dec 09, 2005 7:03 pm
Thats cool, Im not much of a big fan myself. But I was just suggesting it.
Users browsing this forum: No registered users and 106 guests
