SolaraGuy.com • View topic - OEM v aftermnarket front stress bar
Postby widow's son » Thu Jan 09, 2003 3:11 pm
Does an aftermarket front stressbar have any advantage over an OEM?
Also what is the "best" aftermarket front stress bar?
widow's son
Postby cdssolara » Thu Jan 09, 2003 4:59 pm
What is a stress bar? Do you mean sway bar, or possibly strut tower bar?
cdssolara
Postby widow's son » Thu Jan 09, 2003 9:23 pm
I meant a strut tower bar.
widow's son
Postby Blaze » Thu Jan 09, 2003 9:35 pm
if ur thinkin bout getting the 1s off ebay or cheap 1s theyr not worth it
Blaze
Postby cdssolara » Fri Jan 10, 2003 2:29 pm
The TRD strut tower bar is an option, but unless you have a supercharger, there's really no reason to get one. It was designed to be used with the supercharger because the stock strut tower bar was too big to allow the supercharger to fit. Frankly, the stock bar looks like it provides more stiffness than the TRD unit, although I've been told that the TRD one is marginally stiffer. Assuming you still use the stock bar, I wouldn't bother looking into an aftermarket bar unless you get the supercharger.
cdssolara
