SolaraGuy.com • View topic - Big Bore throttle bodies soon to be available for v6's
Postby trd4life » Sun Dec 11, 2005 2:56 pm
I have recently purchased 20 OEM throttle bodies which i will be sending out to be ported and polished. I expect a 3-4mm increase in size. Price has yet to be determined, i hope to be able to sell them to forum members for $200 shipped.
Here is what is done to the OEM throttle body.
First, the throttle bodies are dissasembled, that includes all the sensors and all moving parts. Then the throttle body is sand blasted with ultra fine sand. It is then cleaned and all sand is removed. The throttle body then goes to the lathe, where it is bored, then ported and finally polished. the opening of the throttle body gets a taper that begins at 6 degrees then 3 degrees. A new bigger butterfly is made out of brass. It is then carefully fitted to the throttle body. Once the proper seal is achieved the throttle body is reassembled. The throttle position sensor (TPS) is reinstalled using new screws and it is set to factory specs.
I will be doing a before and after Dyno on the "RedKnight" to see how much power is gained before i put them up for sale.
I'll keep you guys posted!
Gabe
Postby Midias » Sun Dec 11, 2005 3:14 pm
200 count me in first
Is there a discount for people who send back there stock ones to you.
Postby houtrd00 » Sun Dec 11, 2005 3:18 pm
would def like to see the dyno gains when u get them but count me in
houtrd00
Postby ~Spadwaller~ » Sun Dec 11, 2005 3:23 pm
WHoa! I haven't been this pleasantly surprised since I found 3 twenty dollar bills on the ground. "finders keepers" :)
~Spadwaller~
Postby 2002greenhornet » Sun Dec 11, 2005 7:16 pm
Is this only for supercharged applications?
Steve
2002 SLE V6
2002greenhornet
Postby bassthrive » Sun Dec 11, 2005 7:21 pm
I wonder how much this will help a N/A engine...
I also wonder how well it will work in combination with CPE's MAF-ci system...
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby 2002greenhornet » Sun Dec 11, 2005 7:28 pm
bassthrive wrote:I also wonder how well it will work in combination with CPE's MAF-ci system...
Funny you should ask that. My CPE MAF-ci system should be arriving this week...
Steve
2002 SLE V6
2002greenhornet
Postby Sp33d » Sun Dec 11, 2005 10:38 pm
count me in.
-mark
Sp33d
Re: Big Bore throttle bodies soon to be available for v6's
Postby Vampire » Sun Dec 11, 2005 11:30 pm
Gabe, how is this going to affect tuning your fuel map? I assume you don't have to dial the MAF down as much with bigger injectors. Hmm... more air, bigger injectors needed?
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby dominoSLEV6 » Mon Dec 12, 2005 12:01 am
I'm on the floor if the kite's in the air.
(It's a clever(ly stupid) way of saying I'm down if it's functional to a noticable degree)
I doubt the helpfulness of this to an NA car, but it won't hurt anything, and like alwyas, I plan to be eventually boosted.
-chris
dominoSLEV6
Postby AznDragonV » Mon Dec 12, 2005 12:40 am
does this add alot to hp? or torque?
AznDragonV
Postby StockSolara » Mon Dec 12, 2005 2:00 am
AznDragonV wrote:does this add alot to hp? or torque?
your gonna get like 5 hp off of this
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
TB
Postby trd4life » Mon Dec 12, 2005 5:53 am
Paul, i am sure it will lean the car out a "little bit" on the top end for supercharged applications, i'll take care of that on the dyno if need be using the safc. I have been doing some thinking, in order for this mod to be more effective, it "may" require port matching the supercharger. I am going to see if there are any gains without port matching the s/c, then i'll port the s/c and see if there is any diff.
pics coming up soon!
Postby SleeperSolara » Mon Dec 12, 2005 10:35 am
Yeah can we send you our stock ones for the bigger one??
It would keep my stocky pile down. :lol: :lol:
Postby methyl mike » Mon Dec 12, 2005 11:08 am
Sweet! Count me in, will this work on a N/A with the Cpe maf? Im thinking of getting one, and hopefully soon the megans headers. Woohoo my car might actually be fast someday! Yeehaa!!!
methyl mike
