SolaraGuy.com • View topic - a few questions for those of you with remote starters
Postby hari-bhari » Fri Dec 30, 2005 7:23 am
1) where did you mount hte brain for the unit, i can't find a good spot
2) how are you reading the handbrake signal? i found a wire in the plug that goes to the gauge cluster that reads +12V when the handbrake is not engaged and +1V (instead of ground) when the handbrake is engaged. is this the wrong wire?
3) for those of you that have your starter in tach mode, where did you read the tach signal from. i tried reading from a plug in the ecu, but then it somehow got grounded out when i connected it to my starter unit, and my car stopped registering RPMs. I have since disconnected it and my RPMs are back thankfully, but I'm puzzled as to how to get a proper read.
hari-bhari
