SolaraGuy.com • View topic - v6 exhaust works on i4?
Postby skeeter149 » Thu Jan 05, 2006 12:26 pm
hi all i have a 2002 solara with the i4 and am wondering if the v6 exhaust will bolt up. thank all i searched but all the post were just about exhausts in general. have a good one. 8)
getting faster one part at a time.
skeeter149
yes
Postby trd4life » Thu Jan 05, 2006 12:40 pm
yes.
Postby skeeter149 » Thu Jan 05, 2006 12:42 pm
thank you very much greddy evo here i come.
skeeter149
Postby Jai_Jai_Binks » Thu Jan 05, 2006 1:38 pm
yes, i have a trd exhaust (rebranded borla exhaust) that was meant for v6's on my i4!
Postby 1st Gen Sol » Thu Jan 05, 2006 1:56 pm
I got the Greddy EVO on my 99".
It'll fit, on the 01" - 03" Solara's you have to plug up the o2 sensor hole on the bottom but otherwise then that you should have no problem.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby WTF?? » Thu Jan 05, 2006 7:10 pm
1st Gen Sol wrote:It'll fit, on the 01" - 03" Solara's you have to plug up the o2 sensor hole on the bottom but otherwise then that you should have no problem.
Im not sure about the 2001 model, but im darn sure the 2002 will need to have the o2 sensor plugged up. IndigloSolara can tell you what to do to plug up that hole. I think he either used a simple bolt or just bought a o2 sensor itself. The sensor may be easier but pricier
Retired... its been fun Image
WTF??
Postby indiglosolara » Thu Jan 05, 2006 8:59 pm
The Greddy Evo will bolt right up. I used a Dummy o2 sensor to plug up the extra hole meant the the v6 o2 sensor.
when i had the JIC exhaust i used a Bolt the size of the hole and bolted it up with lock tight and thread sealer..
Either way works....
Hope this helps
indiglosolara
Solara 2 xB
Solara 2 xB
