SolaraGuy.com • View topic - WHen do you lack fuel? Is this a sign?
Postby DatSRBoi » Mon Jan 09, 2006 2:25 pm
Every since my car came out of the toyota repair shop and freshy GOOODDDDDDD again. I notice the car seems to be lacking power when I floor it. Back then when I had the check light (CEL) the car stayed in safemode. Now all repair and full mantience has been perform, the cars at its optimun power.
Now Ive read a few old post about fuel issues on boosted car and this and that. But how do you really know when your lacking fuel? Sure I can throw a fuel pressure gauge on the car. But it isnt a cheap investment.
Could this be a sign right here? When I floor my car and boost hits in, I notice the engine makes a weird sound. Of course the beast is awaken. But you can hear this VERY small faint sound. Its like the same sound you hear off civics with fart can exhaust.. That high tone when they try to floor their car and their exhaust makes that horrible fart sound.. Well this is like that but its veryyyy small and its not my exhaust. I cant pin point the exact source because you only hear it when your flooring the car and boost takes in. Is that a sign that my car needs more fuel? The car seems to pull fine.
Hahaha.. Its a wwWWWWEEEEE tatatatatatataatat EEEEEEEEEEEEEEEEEEEEEEEEEE with tatatata in it
Postby Assyrian » Mon Jan 09, 2006 3:15 pm
hmmmm... I wish I could help.... maybe some of the boost gurus can help?
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Postby jhenty » Mon Jan 09, 2006 3:30 pm
i read somewhere you can get vital information about the runnings of your engine by observing the old spark plugs. If you still have them try and look at them and find the article about it. I think it was from dsport magazine. I'll check if I still have it around.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby rnsmelody » Mon Jan 09, 2006 4:40 pm
you are prob getting fuel cut. did you upgrade ur injectors? if so, try upgrading your fuel pump. if you didnt do that already
rnsmelody
Postby Mole » Mon Jan 09, 2006 6:15 pm
if the spark plugs look like calcium color (white/green) it's a sign you are running lean. you can't really tell immediatley on fresh plugs though.
best thing is to get a dyno tune/run. or install an EGT.
Postby BradOwens » Mon Jan 09, 2006 6:54 pm
rnsmelody wrote:you are prob getting fuel cut. did you upgrade ur injectors? if so, try upgrading your fuel pump. if you didnt do that already
this and also wat mole said. if ur runnin lean its not gonna get all tht power and its gonna be dangerous to race it. u should proly tune it.
BradOwens
Postby bassthrive » Mon Jan 09, 2006 8:30 pm
sounds like fuel pump whine
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby DatSRBoi » Mon Jan 09, 2006 9:07 pm
bassthrive wrote:sounds like fuel pump whine
No its coming from the engine bay... Goshie so much to work and tweek out. Dont know where to start.
Postby CASTRO » Tue Jan 10, 2006 12:22 am
oh shoot... I get/got that same exact sound.... before I blew out my knock sensors. Seems like power slowly goes away and before you know it, the knock sensors takes a dump.
Another noise I heard is a very high pitched whine like a constant spooled turbo even at idle. I was thinking its prolly the injectors. Strange because I never had it until I upgrade to Jims Fuel lines
CASTRO
