SolaraGuy.com • View topic - 3SGTE Head
3SGTE Head
3SGTE Head
Postby Chose » Mon Jan 23, 2006 10:11 am
I was told somewhere that I can swap my 5SFE head for a 3SGTE head. Is that true? If so how much work am I lookin at, custom fabrication n crap?
Chosen Few
Chose
Postby dominoSLEV6 » Mon Jan 23, 2006 2:14 pm
I think you can swap the whole motor out and it will work with your 5SFE tranny, as for the heads alone... I doubt it, but I know little to nothing about either engine so maybe you can ask around on celica and MR2 forums etc. and see what's up.
-chris
dominoSLEV6
Postby Jai_Jai_Binks » Mon Jan 23, 2006 2:31 pm
5s block is not rev happy like 3s block...something about us having longer strokes than a 3s version one. from my celica knowledge: mating a stock 3SG head to a stock 5S bottom end will hurt compression because of the differences between the combustion chambers of the different heads and also cus of the piston design. you gain torque, but loose hp! so in other words not an easy swap..but is it worth it? some claim high revs are attainable, but to what extent are willing to test this yourself to see if compressions is ok..your call. I'd rather not if i were you!
Postby TheTamago » Tue Jan 24, 2006 12:36 am
At Toyotanation, theres been some heavy discussion about the 5SFE to 3SGTE Engine swaps. Only thing I can so far to understand though, its the whole engine and all the components plus using a MR2 transmission thats been converted for FF driving.
TheTamago
Postby pythonjosh » Tue Jan 24, 2006 2:37 am
There's tons of talk about this at www.mr2oc.com
pythonjosh
Postby Turbosolara » Wed Jan 25, 2006 3:42 am
it will cost you alot of money because the 5sfe you have is very different from the mr2. few things will fit and few thing will not. i think you will also need to buy a stand alone ecu to operate this setup, which will cost you about 1500-2000 dollars and intensively tuning and headaches.
to directly drop in a 3sgte will be a better solution
