SolaraGuy.com • View topic - TRD Sway Creaks Again
Postby Solorange » Mon Jan 23, 2006 7:40 pm
Thats right what the title says. Ive regreased once already with the white lithium grease. Its starting to creak again. I dont know what to do. Im probably just going to let it go for a while cause its being a pain. Im guessing the cold weather may have something to do with it so Ill fix it when it warms up. Do you guys have this problem? And does anybody have any ideas on how to fix the creaking? ~ Chris
Postby Jon11582 » Mon Jan 23, 2006 11:40 pm
Grease + plumbers tape + more grease, then bushing.
Ive had it on for about a year and a half now through two NJ winters, no creaking.
2000 Black Solara SE
Jon11582
Postby SleeperSolara » Tue Jan 24, 2006 8:22 am
I still have the teflon tape on the bar, and i lithium greased the bushin' alot.
To the point where when i stuck the bushin' back on the bar it oozzed out alot of the grease out. :D
Postby Solorange » Tue Jan 24, 2006 7:51 pm
Some what your saying is next time I go under there and regrease it, I should just use the whole tube. Ok I got that. Ill do that next time ;). When you say plumber's tape is that the same as teflon tape? I know what teflon tape is.
Postby SleeperSolara » Tue Jan 24, 2006 9:03 pm
Solorange wrote:Some what your saying is next time I go under there and regrease it, I should just use the whole tube. Ok I got that. Ill do that next time ;). When you say plumber's tape is that the same as teflon tape? I know what teflon tape is.
No not the whole tube man. :lol:
Just the length on the inside of the bushin'and line.
Postby Jon11582 » Tue Jan 24, 2006 9:19 pm
I think he means the whole tube of grease.
Grease should be oozing out when you tape it up. Then grease should be oozing out when you pu the bushing on.
I dont know if teflon tape is the same as plumbers tape.
Jon11582
Postby SleeperSolara » Wed Jan 25, 2006 8:31 am
Well you don't need the whole tube, they come in a big tube.
A nice squeze on the tube to make a line of lithuim grease on the inside of the bushin' will be fine.
