SolaraGuy.com • View topic - Spark Plugs
Spark Plugs
Spark Plugs
Postby jim@foreignaffairs » Thu Jan 26, 2006 2:45 pm
For some time I was having a lot of problems with the spark plugs in the SuperSolara. I switched to Denso Iridium plugs, but 3 of the 6 failed one by one. They didn't have more that a couple thousand miles on them before the first one went, and when the second one stopped sparking I began looking for a better alternative. Luckily each of the failed ones were easy to get to without the removal of the S/C: 2-4-5. Well I found what I believe is the better alternative. These plugs are used in the late model BMW "M" cars. They are an NGK Platinum plug with 4 cathodes (sometimes refered to incorrectly as ground electrodes). Anyway, I have had them in for quite some time now with no failure and they feel at least as good power-wise as a new set of Denso Iridiums. Part number is: BKR6EQUP (Stock number 3199). You might want to give them a try. Because they have multple cathodes, they also solve the question of using a multiple cathode platinum plug as recommended by Toyota.
Jim
jim@foreignaffairs
Postby jhenty » Thu Jan 26, 2006 2:54 pm
i went to sparkplugs.com and ordered the champion iridiums and they seem to be working fine.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby SleeperSolara » Thu Jan 26, 2006 6:53 pm
That a good alternative.
Postby StockSolara » Fri Jan 27, 2006 1:56 am
Good stuff. . . I'll do that later if my densos do end up failing
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby lilm » Sun Jul 20, 2008 3:09 pm
ya ya i know old old ooooollllld post but is anyone actually running these other than jim?
lilm
Postby 5sfe » Sun Jul 20, 2008 7:18 pm
iam runing some brand new NGK the best of the best i suppose.....well first i put the carpy ones from NGK and then i read on the side of my engine said it only takes Iridium and iam like holy sh** so took the crapy ones out and put the NGK Iridiums..$10.47 it cost me for all four like 45 something dollars too much money for something that just sparks
5sfe
Postby lilm » Sun Jul 20, 2008 7:41 pm
ya they are just so damn expensive im up for getting ik22's but i was wondering if anyone actually started running these not only are they recommended by jim but they are like 3 bucks cheaper
lilm
Postby lexmex » Fri Jul 25, 2008 2:46 pm
Those NGK plugs look very similar to the Torquemasters that I use that are also four pronged.
This is their webpage, www.extremespark.com but I have some photos of the actual ones in mine on this DIY that I did for my RX300, http://www.clublexus.com/forums/showthread.php?t=264967
lexmex
Users browsing this forum: Google [Bot] and 100 guests
