SolaraGuy.com • View topic - Cheap 15 HP increase!
Postby Monkeyman » Mon Jan 30, 2006 4:36 pm
I added a K&N air filter to my factory air box (no CAI), and Lucas Oil Stabilizer to my engine oil, and to my gear lube. I am also using Lucas Fuel Treatment in my fuel. According to my G-Tech meter I now have 15 horsepower over stock! In addition my RPM's @ 75 MPH dropped 175 RPM's. While that isnt a huge drop, it means my top end might be higher than 120 MPH now ("MIGHT" be, NOT "is").
It was damn cheap too!
K&N Filter: $35.00
Lucas Oil Stabilizer: $12.00
Lucas Fuel Treatment: $8.00
Fifteen horsepower for only $55? Who wouldn't do that! By the way MANY drag race teams, nascar teams, etc. use Lucas Oil products, so yes it is that good!
www.LucasOil.com
Monkeyman
Postby AznDragonV » Mon Jan 30, 2006 4:59 pm
would u have to add more of the oil stabilizer and the oil treatment each time you get gas after u run out?
AznDragonV
Postby bluesolara » Mon Jan 30, 2006 5:09 pm
AznDragonV wrote:would u have to add more of the oil stabilizer and the oil treatment each time you get gas after u run out?
Not always, like every other, or you could do it each time. Costs $$
2001 Indigo Ink Pearl SE
God bless.
bluesolara
Postby Monkeyman » Mon Jan 30, 2006 5:15 pm
Yes, but @ $8.00 for almost a liter of the fuel stabilizer it is cheap enough to do. You only have to put in about 2-3 ounces for 10 gallons of fuel, so a liter will last about 10-16 fills (1 Liter = 33.81 ounces) so it will cost you $0.48 to $0.72 per fill up. In terms of the Oil Stabilizer you only have to add 25% of your oil capacity, so you will get about 4 oil changes per liter of Lucas Oil Stabilizer ($12/4 = $3.00 per oil change).
Monkeyman
Postby SleeperSolara » Mon Jan 30, 2006 5:49 pm
Cool man.
Postby dominoSLEV6 » Tue Jan 31, 2006 12:00 am
I'm really not sure how much the oil stablizer helps the HP effort. I guess any rotating assemblies can be less restricted... of course I'm too ignorant and lazy to check out the lucas oil site right now to see exactly what this stuff does, but it sounds sweet.
I put a K&N filter in my stock airbox on the ca rI have now and didn't notice a differenc ein anything, I figured it was good for maybe 2.5 hp at absolute best
-chris
dominoSLEV6
Postby Yanks0114 » Tue Jan 31, 2006 1:22 am
I'm sorry to say buth your G-Tech is wrong. They are inaccurate by nature, and this just proves it.
As domino said, the KN is good for 0-5HP and the stabilizer really wouldn't do much.
There is no cheap way to gain HP, however, you're on the right path.
Postby Monkeyman » Tue Jan 31, 2006 7:18 am
Lucas Oil Stabilizer helps turn the oil into a polymer like structure, so it forms a continuous film over the metal (it is not a polar covalent bond between molecules, but even a hydrogen bond is pretty strong). This allows it to cling to the underside of piston rings, which increases compression, thereby increasing horsepower. Will Dyno this afternoon for "true" numbers.
Monkeyman
Postby SeanJohn0716 » Wed Feb 08, 2006 5:32 am
Results?
SeanJohn0716
Postby xavier » Wed Feb 08, 2006 6:44 am
I believe horsepower tv did a dyno on a z28 with generic oils and then drained the crankcase, rear diff, and transmission...filled all three with lucas oil stuff and a lucas fuel additive. then they dynoed again. They gained about 30 hp. while I realize that the 350 probably had more resriction, however, I believe that the right oils will net you more power to the wheels. they dont actually add hp though. They just reduce what your drivetrain absorbs due to friction.
xavier
Postby SPF 0 » Wed Feb 08, 2006 8:12 am
No offense, but this just doesn't pass the smell test for me.
SPF 0
Re: Cheap 15 HP increase!
Postby Down2TheC » Fri Feb 10, 2006 5:46 am
Monkeyman wrote:In addition my RPM's @ 75 MPH dropped 175 RPM's. While that isnt a huge drop, ...
:o :o :o :o :o :o :o
Sorry dude... but you're being a total moron. If your RPM's dropped at a particular speed... that means your trans has issues.
That has nothing to do with power.
Whether you're stick (especially if you're stick) or auto, your gear ratio doesn't change with your choice of oil and any auto trans
would be locked up at 75 so... same thing.
I hope you're kidding... please say you're kidding.
:roll:
Down2TheC
Postby Down2TheC » Fri Feb 10, 2006 6:01 am
Monkeyman wrote:In terms of the Oil Stabilizer you only have to add 25% of your oil capacity, so you will get about 4 oil changes per liter of Lucas Oil Stabilizer ($12/4 = $3.00 per oil change).
Not to flame but while we're at it, 1 liter = 1.056688 quarts. So one liter of the stuff is about what you'd need each oil change.
Down2TheC
Postby jazzlara » Sat Feb 11, 2006 5:55 pm
you know chitown brother, you didnt have to call him a moron, did you?
this weather is gettin to me too, we should go for a cruise sometime..harass some females hehe
jazzlara
Postby PXLpainter » Sat Feb 11, 2006 7:03 pm
Well - I'm no big believer in "snake oil" additives, etc... but I do know from experience that the K&N (or TRD) drop in filters will help response and overall performance because it can let the engine BREATHE - and... I've always run Mobil 1 synthetic from the first oil change on and that has done me well for last 4 cars.
Not sure how any additve will gain HP - but less friction and oil stability will definitely help parts last longer - which is why I stick with the Mobil 1. Never tried gas additives - always heard they were a waste of $$.
My 2¢ FWIW ;)
JF
