SolaraGuy.com • View topic - Is300 rims
Is300 rims
Is300 rims
Postby sydemoid » Tue Jan 31, 2006 12:47 am
Hey guys...
Well, I purchased a set of mint IS300 rims with tires from a friend.
The big brake kit will go on soon enough!>... and I cant wait!!!
For the time being though, I will probably use regular rotors.... Once I get the info Im waiting on for the possible 4 piston calipers, and order the steel braided lines.... I wont go with x-drilled or slotted rotors, Im pinching my pennies folks!
Well, Im going to bed.... I spent a majority of my check on them, and Im sleepy...lol
sydemoid
Postby SleeperSolara » Tue Jan 31, 2006 8:19 am
Don't forget wheel spacers.
Good luck man.
Postby sydemoid » Tue Jan 31, 2006 11:35 am
why would I need spacers?
sydemoid
Postby WJN333 » Tue Jan 31, 2006 12:36 pm
With certain tires, the rubber will rub the strtus in the rear. since the IS300 wheels have an offset of 50 i believe. I have IS300 rims on now without spacers and they do not rub. However I am going to put a set of spacers in so I dont rub when I change tires. The spacers are inexpensive and will make sure that the tires do not rub the struts. You can probably get a set second hand here on the forum like I did very inexpensively. Thank you RichD978.
Currently running Potenza G009 225/45/17 tires.
WJN333
Postby sydemoid » Tue Jan 31, 2006 12:40 pm
Oh, ok...
you guys always look at things from different perspectives....
Im running 215 45 17 dunlop sp sport 9000's
Im going to see if they rub, but it shouldnt matter much, since my original intentions are to run coilovers.... God willing.
I will look into this, and get at you guys with any further info later on.
sydemoid
Postby Solorange » Tue Jan 31, 2006 9:01 pm
Post some pics when you get them on. I love is300 wheels on solaras!
Postby BigPhizzle » Wed Feb 01, 2006 12:23 am
IS300 rims on a Solara? Im dying to see what that will look like
- Big Phizzle -
BigPhizzle
Postby JavaJoe_2 » Wed Feb 01, 2006 5:36 am
I have them on a Gen4.5 Camry.
I am under the impression that our platforms are the same.
I don't have spacers and they don't rub.
I'm lowered and have TRD/Tokicos with 215/45/17 tires.
Got Boost?? :sweet:
JavaJoe_2
Postby Mole » Wed Feb 01, 2006 10:17 am
It will fit, however adding a spacer would be nice to make it flush with the wheel wells.
