SolaraGuy.com • View topic - Indaglow Gauge Question?
Postby Dave » Fri Jan 17, 2003 8:47 pm
I just installed the reverse gauges! They look great if I dim the factory lights. Problem, can't see the radio or climate controls.... Is there a way to kill the factory gauge lights without killing the orange needle lights? I hate you can seen the faint light from the factory gauges..... They still look good but could look better!~!
Dave
Re: Indaglow Gauge Question?
Postby Yanks0114 » Fri Jan 17, 2003 10:59 pm
Dave wrote:I just installed the reverse gauges! They look great if I dim the factory lights. Problem, can't see the radio or climate controls.... Is there a way to kill the factory gauge lights without killing the orange needle lights? I hate you can seen the faint light from the factory gauges..... They still look good but could look better!~!
Just remove the bulbs behind it, thats what i did
Postby TadS » Fri Jan 17, 2003 11:09 pm
Are you talking about the green lights? If so, just pull the bulbs. That's what I did at least. There are like 6 or 7 of them. They are the larger ones. One of the lights illuminates your odometer, so you may want to leave that one in. :) This link talks about the changing the lights on the Camry. The application is different, but it should give you an idea what to look for, if I understand your problem.
TS
http://www2.hawaii.edu/%7Echarlsto/dashlights.html
TadS
Postby xyntax » Sat Jan 18, 2003 11:25 am
I would give the same advice as these people did. Mind telling us what reverse gauges you got? and from where? Thanks
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
