SolaraGuy.com • View topic - Back-up sensor..........
Postby SleeperSolara » Fri Feb 03, 2006 9:42 am
You guys think it worth it????
It off Ebay.
http://cgi.ebay.com/ebaymotors/Toyota-Prius-RAV4-Scquoia-Sienna-Solara-backup-sensor_W0QQitemZ8035597033QQcategoryZ33721QQrdZ1QQcmdZViewItem
It $18 and $18 s/h.
So about $36 shipped for 2 sensors.
Additional is $15 more.
I do back up alot........
Also they have the digitial read out too for $20.
Wanted to see what you guys think.......
Postby SolaraGuy22 » Fri Feb 03, 2006 9:47 am
Sounds good to me, if you get it let me know how it works.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby SleeperSolara » Fri Feb 03, 2006 9:51 am
SolaraGuy22 wrote:Sounds good to me, if you get it let me know how it works.
Ok will have to see about that later.......
Postby Jai_Jai_Binks » Fri Feb 03, 2006 12:11 pm
they sell them in different colors, The digi readout is ghay! not worth it, If you can go for the beeping version...go for the three sensors imo, and they do look and work, i've used them abroad on a camry (aftermarket installed).
Postby SleeperSolara » Fri Feb 03, 2006 3:33 pm
Jai_Jai_Binks wrote:they sell them in different colors, The digi readout is ghay! not worth it, If you can go for the beeping version...go for the three sensors imo, and they do look and work, i've used them abroad on a camry (aftermarket installed).
They only sale 2 per set.
Postby MCOjerry » Fri Feb 03, 2006 3:48 pm
Sleeper...do you hit a lot of things when you back up? If you don't, don't get it. If you do, then you might want to consider it.
Personally, the black will stick out like a sore thumb on anything but a black car, and the other colors would probably not match well.
Just back up carefully and you won't have to worry :-)
Postby krook » Fri Feb 03, 2006 5:17 pm
DEI also makes a reverse aid system. like Viper alarms, the same quality goes into their reverse aid systems as well.
usually with reverse aid systems, the sensor will ocassionally "go bad", and they'll need to be replaced. however, i haven't had any problems with DEI reverse aids, and i've installed about 20 so far.
krook
Postby SleeperSolara » Sat Feb 04, 2006 9:47 am
Actaully no i don't hit anythin' when i back up.
Just thought it would be a nice convience to have on the car.
Postby MCOjerry » Sat Feb 04, 2006 9:56 am
SleeperSolara wrote:Actaully no i don't hit anythin' when i back up.
I wouldn't get it then. I just don't think it will look good. The white will probably not match your car at all.
