SolaraGuy.com • View topic - juss curious, but....
Postby HwEaNnRgY » Sun Jan 19, 2003 10:39 pm
did anyones solara come something showing the temperature? i had an avalon before the solara so im not really used to not having one when its freezing cold in the morning. Also is it just me or is it really uncomfortable only having one light in the middle of the car instead of having 2, with one by the garage opener?
HwEaNnRgY
Re: juss curious, but....
Postby Flipside909 » Sun Jan 19, 2003 10:59 pm
HwEaNnRgY wrote:did anyones solara come something showing the temperature? i had an avalon before the solara so im not really used to not having one when its freezing cold in the morning. Also is it just me or is it really uncomfortable only having one light in the middle of the car instead of having 2, with one by the garage opener?
Solara's with Outside temp guages are found on SLE models only...which is located at the digital HVAC control unit.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Guest » Mon Jan 20, 2003 8:46 am
HwEaNnRgY wrote:Also is it just me or is it really uncomfortable only having one light in the middle of the car instead of having 2, with one by the garage opener?
you could always wire up your light by the garage opener to work simultaneously with your dome's light.
Guest
