SolaraGuy.com • View topic - bolt on performance
bolt on performance
bolt on performance
Postby solaraguy777 » Wed Jan 22, 2003 4:36 pm
I have an exhaust and intake on my solara whats the next thingi could bolt on besides the s/c?? and nos?
xr7danz777@aol.com
solaraguy777
Postby Blaze » Wed Jan 22, 2003 4:46 pm
dont put nos on it, save up for a s/c
Blaze
Postby krook » Wed Jan 22, 2003 5:27 pm
TRD bodykit?
krook
Postby Blaze » Wed Jan 22, 2003 5:32 pm
is a bodykit performance though? :P
Blaze
Postby happy_aggies » Wed Jan 22, 2003 7:13 pm
Headers, plugs, wires and the new Altezza tail lights! :angel:
happy_aggies
Postby _nkx1 » Wed Jan 22, 2003 7:19 pm
According to some people on the board (Flipside to name 1), you could take your intake out. You may get better gas mileage and better performance from a stop (when the car is stopped, the intake sucks hot engine air, which decreases performance). I'm not talking from experience, but just what I've read here.
_nkx1
Postby krook » Wed Jan 22, 2003 7:25 pm
Blaze wrote:is a bodykit performance though? :P
d'oh ....d'oh! ....d'oh!
krook
xr7danz777@aol.com
Postby solaraguy777 » Thu Jan 23, 2003 1:21 pm
What companies make headers for the solara do wires realy do any good?
solaraguy777
Re: xr7danz777@aol.com
Postby cdssolara » Thu Jan 23, 2003 2:28 pm
solaraguy777 wrote:What companies make headers for the solara do wires realy do any good?
No companies make a header for the Solara. However, Ericsol, who sometimes posts on this forum, has had some custom headers built. I think that his mechanic can make duplicates. If you're interested, there is a thread here that he started about the headers. You can find it, and post a response. I'm sure he'll get back to you. If you don't reach him on this forum, try camryman.org or teamsc3.com.
As for the wires, they won't give you any additional hp, but they may keep you from losing some.
cdssolara
Re: bolt on performance
Postby cdssolara » Thu Jan 23, 2003 2:30 pm
Guy wrote:I have an exhaust and intake on my solara whats the next thingi could bolt on besides the s/c?? and nos?
xr7danz777@aol.com
If you're not just talking about power, you could install lowering springs and performance struts.
cdssolara
solaraguy777
Postby Guest » Thu Jan 23, 2003 5:56 pm
i dont want my ride to be all crapy from lowering springs
Guest
Postby Blaze » Thu Jan 23, 2003 6:02 pm
if u get strut/spring combo it wont be
Blaze
Postby cdssolara » Thu Jan 23, 2003 6:31 pm
If you drop your car 3" simply for the sake of appearances, your ride will probably suffer. However, if you just want handling improvements, get a spring that will lower your car about 1.5" along with a strut that will match it. Your handling will improve tremendously, and your ride will actually be more comfortable at higher speeds than the overly soft stock set-up. At lower speeds you won't notice much change except when you go over serious bumps.
cdssolara
Postby Guest » Fri Jan 24, 2003 8:59 am
_nkx1 wrote:According to some people on the board (Flipside to name 1), you could take your intake out. You may get better gas mileage and better performance from a stop (when the car is stopped, the intake sucks hot engine air, which decreases performance). I'm not talking from experience, but just what I've read here.
Thats plain horse crap. Any person who dynos with any Intake Mods will see a difference. It may not be very noticable(with a max gain of 4-8 HP on Forced Induction IMZs), but you will gain. If you get a decent intake for around 100 bucks like I did, its DEFINATELY worth it, especially if you wanna keep going with the modifications.
Aviv
Guest
Postby nkx1 » Fri Jan 24, 2003 10:12 am
It really depends on how the intake is designed. If the intake is a short ram, which means it inducts air from the engine bay, you are likely going to lose power, particularly when starting from a stop. This is because you will be sucking in hot air which has significantly less oxygen than cold air. (Oxygen, of course, being the element that you are trying to increase) A cold air intake may net you a little power, but even then the effects are sometimes negligible on a Solara, and you still might be better off with the stock intake. Also, I've read that cotton K&N-type filters allow more dirt/dust than paper filters to your engine. This will obviously lead to increased wear and tear on your engine. Of course, there is debate about that, but that should probably be a whole other topic.
2001 SLE, Diamond White Pearl
nkx1
