SolaraGuy.com • View topic - What could cause this???
Postby Danny » Fri Jan 24, 2003 3:29 pm
My buddy has a v6 solara supercharged with injen intake and greddy exaust and we dynoed his car and he hit 202 whp. I think the best thing to do is buy a boost guage but. does anyone have any answers to this???
Danny
Postby Luc » Fri Jan 24, 2003 4:13 pm
My friend with his S/C'd Gen4.5 dynoed about 190 whp at first, then 206 whp after S-AFC tuning, with stock system. It's the limitation of the A/T.
Luc
1998 S/C'd 1MZ-FE A/T
Luc
Postby impactX » Fri Jan 24, 2003 8:18 pm
If it's A/T, that figure sounds right
impactX
it was a manual
Postby Guest » Fri Jan 24, 2003 10:06 pm
his car was a manual transmission.
Guest
Postby impactX » Sat Jan 25, 2003 3:13 am
What altitude?
impactX
altitude
Postby Danny » Sat Jan 25, 2003 3:34 pm
this was in redlands maybe 1000ft or less, still wondering whats causing such low wheel hp.. on the manual
Danny
Postby Yanks0114 » Sat Jan 25, 2003 3:58 pm
Not sure what kind of effect this would have, but try going back to the stock air box.
Also what did you dyno this with?
dyno tune
Postby Danny » Sat Jan 25, 2003 4:23 pm
this was done on a dyno jet, do you experience any lag or stutter with a 6psi pulley without a the afc tuned. Could it be something wrong with the internals of the s/c?? any way he got a boost guage were gunna check it out today
Danny
Postby 20SoLaRa02 » Sun Jan 26, 2003 2:01 pm
i think the prob might be the 6 psi pulley...not sure though. I've heard wit that high of boost u need to get a s-afc to manage the air/fuel ratio because u will run either to rich or lean...not sure on that either. Either that's the prob or there is something definitely wrong......Goodluck
Does n e body know what a stock v6 s/c manuel should be at for fwhp???
that way he has some figures to compare too
20SoLaRa02
Postby Yanks0114 » Sun Jan 26, 2003 2:09 pm
If i remember correctly its 227 FWHP and with intake and exhaust he should be at 235FWHP @4 psi
reply to yanks
Postby Danny » Sun Jan 26, 2003 10:40 pm
ive heard all those figures before, ok update today we installed a boost guage ran down the street at 4psi was were the needle stopped when the car dynoed it had injen intake, tanabe exuast and 4psi pulley the hood was open and a large fan was blowing striaght at the car. The figures came 202 fwhp and i think 206 trq this was on a dynojet in redlands california. please some one have an answer to this problem why isn't it hitting at least close to 220 or 230. Also the supercharger is starting to have mild bearing noise, but the dyno was about 4 months ago with no noise. PLEASE HELP.
Danny
Postby 20SoLaRa02 » Mon Jan 27, 2003 12:46 am
maybe u should try another dyno if that's possible......or/and go run ur car and tell what the 1/4 mile is.....lol.....and we'll compare with other people
20SoLaRa02
Postby Danny » Mon Jan 27, 2003 1:30 am
any idea of what the nosie might be it only occures during moderate acceleration. should i worry??
Danny
Re: reply to yanks
Postby Flipside909 » Mon Jan 27, 2003 2:32 pm
Danny wrote:ive heard all those figures before, ok update today we installed a boost guage ran down the street at 4psi was were the needle stopped when the car dynoed it had injen intake, tanabe exuast and 4psi pulley the hood was open and a large fan was blowing striaght at the car. The figures came 202 fwhp and i think 206 trq this was on a dynojet in redlands california. please some one have an answer to this problem why isn't it hitting at least close to 220 or 230. Also the supercharger is starting to have mild bearing noise, but the dyno was about 4 months ago with no noise. PLEASE HELP.
I was under the impression you had a Solara. But anyways, your friend is having serious problems if he's only getting 202 to the wheels at the dyno.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Danny » Tue Jan 28, 2003 9:55 am
i also have a solara well we figured out thats it a problem by only hitting 202 thats obvious, do you have any ideas on what is making it so low the car is boosting 4psi on a boost guage so there is boost be we still have no idea why it would be so low
Danny
