SolaraGuy.com • View topic - what kind of oil??
what kind of oil??
what kind of oil??
Postby sahuddleston » Mon Mar 06, 2006 1:55 pm
hey guys, when i get the solara back from ZPI its due for an oil change... its got around 60k on it. is there a specific type of oil or weight that i should be using??? synthetic or regular??? i was thinking about quaker state for high performance engines...
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby swindler » Mon Mar 06, 2006 2:15 pm
I think you'll find several other threads on here where the predominant oil being used seems to be Mobil 1 synthetic, 5W-30, which happens to be what I use, with the K&N oil filter. Some push the weight around for seasonal use, but I think you'd be fine in Walmartville with the standard weight.
2006 SLE V6 Convertible
swindler
Postby Mandarinsolara » Mon Mar 06, 2006 2:31 pm
yea just pick up some QS high performance
Mandarinsolara
Postby hskrsolara » Mon Mar 06, 2006 2:36 pm
mobil 1 full synthetic all the way.
hskrsolara
Postby Leets » Mon Mar 06, 2006 4:00 pm
Shell Rotella T Synthetic 5W-40
... your engine and your wallet will thank you. :wink:
Leets
Postby Hsakuragi » Mon Mar 06, 2006 4:28 pm
oh no...not again...
Hsakuragi
Postby Elfumador » Mon Mar 06, 2006 8:38 pm
Royal Purple, with a K&N oil filter
Elfumador
Postby Jackass-Jeff » Mon Mar 06, 2006 8:50 pm
since you're running F/I, go with Mobil1 Synthetic. Due to higher ambient temperatures from F/I, the synthetic would be the smart choice (less degradation in higher than normal temps).
god speed.
Jackass-Jeff
Postby sahuddleston » Mon Mar 06, 2006 8:51 pm
think i decided on mobile 1 synthetic...... 5w- 40???? what weight???
sahuddleston
Postby Jackass-Jeff » Mon Mar 06, 2006 8:55 pm
stupidrunner54 wrote:think i decided on mobile 1 synthetic...... 5w- 40???? what weight???
10w30 or 10w40
how cold does it get in your area? if it gets cold, then run 5w30
Jackass-Jeff
Users browsing this forum: Majestic-12 [Bot] and 37 guests
