SolaraGuy.com • View topic - Swaybars.
Swaybars.
Swaybars.
Postby vin » Tue Mar 14, 2006 10:46 am
I'm wondering where's the best place to find swaybars for my ES300, which shares the same suspension as the Solara/Camry.
Online or locally.
I'm looking at the Whiteline fsb and TRD rsb.
vin
Postby CASTRO » Tue Mar 14, 2006 11:30 am
Even though the swaybars are similar, they are not 100% the same. You will have to get the camry or solara endlinks as the stock ES300 endlinks will not fit in either the strut or swaybar hole. Trust me, I know. hehe
CASTRO
Postby vin » Tue Mar 14, 2006 11:44 am
CASTRO wrote:Even though the swaybars are similar, they are not 100% the same. You will have to get the camry or solara endlinks as the stock ES300 endlinks will not fit in either the strut or swaybar hole. Trust me, I know. hehe
thanks for the heads up!
vin
Postby MentatGom » Thu Mar 16, 2006 2:13 am
Hi,
What year ES300?
I have a 1999 Camry and two 1997 ES300s.
I installed Whiteline swaybar sets on all 3. The stock parts were identical between my two ES and my Camry. I had no problem doing the installs on the ES at all.
Whiteline stuff can be ordered online at www.globalperformanceparts.com or www.185performance.com
I have ordered 1 set from 185 and 2 sets from global. Personally had better luck with global.
MentatGom
Postby ---CAMRAZY--- » Thu Mar 16, 2006 9:52 am
I installed a TRD Rear Sway Bar on my 94 Camry and it fit with no problems... Here is the link, $167. and change, shipped... http://www.trdsparks.com/ Just bought it last month, brand spankin' new.
Postby vin » Thu Mar 16, 2006 9:59 am
Thanks for the info guys.
I'm a little concerned that I will have to buy the end links like Castro said. I checked the prices on those and its a little pricey.
MentatGom, my ES is a `97, did you have any problems installing the whiteline bars ?
CamrySE-soCALlara, will that fit the 97~01 Camry/ES body styles?
Thanks again.
vin
Postby ---CAMRAZY--- » Thu Mar 16, 2006 10:03 am
Its the one for the 99-2003 solara, it should fit with no problems.
Postby MentatGom » Thu Mar 16, 2006 2:44 pm
Hey vin,
I had absolutely no problem installing the Whiteline swaybars.
I even have pics from my install on one of my ES here:
http://www.solaraguy.org/viewtopic.php?t=15817
Good luck with whatever you decide to do.
MentatGom
Postby vin » Thu Mar 16, 2006 4:25 pm
Thanks MentatGom!
will the bars fit w/o any additional parts (such as end links)?
Also, if its not too much trouble can you give me the part numbers of those whitelines?
thanks again.
vin
Postby ThatVietGuy » Thu Mar 16, 2006 5:15 pm
I think you will need new bushings for the front swaybar.
For the rear bar, you could use stock, but it'll be a tight squeeze (for the Solara anyway).
On the same note, can someone post a link for the rear bushings? I've been digging through posts and I can't find anything.
ThatVietGuy
Postby MentatGom » Thu Mar 16, 2006 7:34 pm
vin:
Front Whiteline Sway Bar - BTF38
Rear Whiteline Sway Bar - BTR39
If you order new Whiteline Sway Bars, they come with new Polyurethane bushings and grease packs for the install. You can use the stock endlinks and brackets.
ThatVietGuy:
Part number for the rear bushings is SPF1132-20K (if you have a Whiteline)
http://www.globalperformanceparts.com/p ... s_id/19250
MentatGom
Postby vin » Thu Mar 16, 2006 10:32 pm
Thanks for the help guys, I really appreciate it!
`97 ES300: 18" Volk Racing "SS" wheels. Tein SS
vin
Postby ThatVietGuy » Fri Mar 17, 2006 2:57 am
MentatGom wrote:vin:
ThatVietGuy:
Thanks a lot :)
ThatVietGuy
Postby pythonjosh » Sun Apr 02, 2006 4:25 am
ThatVietGuy:
Where can I buy the Whiteline FSB bushings seperately?
pythonjosh
Postby MentatGom » Tue Apr 04, 2006 3:29 am
pythonjosh:
Part number for the front bushings is SPF1132-24K.
You can order from here:
http://www.globalperformanceparts.com/p ... s_id/19253
MentatGom
Users browsing this forum: Google [Bot] and 91 guests
