SolaraGuy.com • View topic - cost of spring installation
Postby SolaraBlue » Fri Mar 24, 2006 5:49 pm
what did it cost you to have your lowering springs installed? anything i should make sure the installers do when installing tein springs on a solara? ive read, make sure they watchout for the abs cable because it can break easy, or something like that..... anything else? thanks for the help.
thanks!
Postby sahuddleston » Fri Mar 24, 2006 6:04 pm
DIY if you can.... save the money and spend some time with the good ol solara
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby SolaraBlue » Fri Mar 24, 2006 6:10 pm
i'd love too however i do not have the means nor the patience to do so :(
Postby Gago » Fri Mar 24, 2006 6:44 pm
mine cost 200 with strut installation
1999 Toyota Solara
2002 - Audi A4 1.8t
Gago
Postby jdsun1 » Fri Mar 24, 2006 7:30 pm
I got spring and struts also put on at the same time and it was about expensive. About 300 I think.
jdsun1
Postby SolaraBlue » Fri Mar 24, 2006 8:03 pm
i wonder if springs alone will be half as much..... anything i shouls watch out for when having these installed? do i have to buy anything to make sure the springs ride well?
Postby Gago » Fri Mar 24, 2006 8:08 pm
SolaraBlue wrote:i wonder if springs alone will be half as much..... anything i shouls watch out for when having these installed? do i have to buy anything to make sure the springs ride well?
yes buy some gas struts or else your ride will feel like a boat
1999 Toyota Solara
2002 - Audi A4 1.8t
Gago
Postby SolaraBlue » Fri Mar 24, 2006 8:37 pm
i plan on it, i have new rims and tires and dont feel like waiting for new struts, i'll buy those half way through the summer.
Postby Gago » Fri Mar 24, 2006 8:51 pm
SolaraBlue wrote:i plan on it, i have new rims and tires and dont feel like waiting for new struts, i'll buy those half way through the summer.
thats good but since you're getting some struts you should do it the same time since to put the springs on it will be the same price as putting struts on you gonna have to pay double if you do one at a time
1999 Toyota Solara
2002 - Audi A4 1.8t
Gago
Postby solarabr » Fri Mar 24, 2006 8:52 pm
got mine installed for 100, neighbor, but its usually around 200 here....
solarabr
Postby Mandarinsolara » Fri Mar 24, 2006 9:27 pm
^ that is a beautiful drop if i may say so
Mandarinsolara
Postby scLara626 » Fri Mar 24, 2006 9:27 pm
jus springs, no more then a hundred
" I heard (YOUR NAME GOES HERE) got fired from the sperm bank for drinking on the job''
scLara626
Postby TadS » Sat Mar 25, 2006 6:33 am
You have to remove the entire strut assembly to do the springs. If you came to the shop I work in you would end up paying for the job twice, not to mention 2 alignments. Just wait until you can do them both at once.
TadS
