SolaraGuy.com • View topic - any spring/strut install pointers?
Postby SolaraBlue » Sun Mar 26, 2006 12:24 pm
is there anything i should make sure the mechanics do during install of tein springs/ tokico struts? i know to watch out for the abs cable, anything else? also i was thinking of buying these struts off javajoe http://www.geocities.com/javajoe_2/strut.html one of them is missing a cap as you can see in the pics, is that going to be a problem?
thanks!
Postby calreef18 » Sun Mar 26, 2006 12:34 pm
Not sure about the missing cap, but as for pointers, make sure when you compress the springs that you do each side a little bit at a time so that there is fairly even pressure on each side. Also, use a torque wrench to get the right specs when you put everything back on. There is a tutorial and diagram in the tutorial section. Gluck, its fun/a pain, and definitely worth it afterwards. :)
calreef18
Postby SolaraBlue » Sun Mar 26, 2006 1:03 pm
i dont plan on doing this myself (mechanically retaarded).... and the pics for this in the tutorial are broken....
Postby Jai_Jai_Binks » Sun Mar 26, 2006 2:22 pm
I see your already familiar with ABS sensors, they do tent to break if not supported well. but looks like your prepared. GL
Postby calreef18 » Sun Mar 26, 2006 6:49 pm
Go to the second or last page of the tutorial, somebody linked a pdf with install diagrams. hth
calreef18
Postby SolaraBlue » Sun Mar 26, 2006 8:16 pm
great! i printed it off. anything else?
Postby SolaraBlue » Sun Mar 26, 2006 9:37 pm
anyone know about the cap on the strut?
Postby bassthrive » Sun Mar 26, 2006 11:05 pm
Tell them to cut the bumpstops (two rings worth).
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SolaraBlue » Sun Mar 26, 2006 11:28 pm
whats that do?
Postby DaTwUnKrAziEpInOy » Mon Mar 27, 2006 12:04 am
the bump stops are to keep your car from bottoming out. It kinda acts like a stopper that keeps your strut from pushing all the way in and trashing your strut, mounts or anything else. The reason for cutting the bumpstops is to create more suspension travel of the strut. Obviously with shorter springs there's less travel for the strut with stock bump stops. Cutting the bump stops will create a bit more travel for the strut. Hope this helps.
DaTwUnKrAziEpInOy
Postby ruffrydasean » Mon Mar 27, 2006 12:07 am
Hmmm.. I wonder if I shoulda cut mine.. but whatever, what's done is done. Make sure whoever is doing has a breaker bar.. I broke 2 ratchets trying to do the rear.. and even then.. the Breaker bar looked like it was ready to snap in two
Click Pic for link to my Cardomain page.
Image]
ruffrydasean
Postby SleeperSolara » Mon Mar 27, 2006 9:53 am
ruffrydasean wrote:Hmmm.. I wonder if I shoulda cut mine.. but whatever, what's done is done. Make sure whoever is doing has a breaker bar.. I broke 2 ratchets trying to do the rear.. and even then.. the Breaker bar looked like it was ready to snap in two
Yeah i've broke my first rachet so far too.......
Good luck man.
