SolaraGuy.com • View topic - Confirmation of Rim Size
Postby Omes01SLE » Thu Mar 30, 2006 2:47 pm
Hi All,
I'm interested in purchasing these rims, just wanted confirmation from the "experts" that they will fit my 2001 Solara SLE.
18 x7.5, dual 5-bolts pattern (5x100/114.3), +42mm offset
Also, what size tire would you recommend?
thanks.
ps. i hope it's ok to post the same question here and on Toyota Nation. thanks again.
Omes01SLE
Postby dominoSLEV6 » Thu Mar 30, 2006 11:07 pm
According to Kennys amazing thread of rim size and fitment according to offset etc. you're fine. +42 or lower.
http://www.solaraguy.org/viewtopic.php?t=13755
The bolt pattern is right.
-chris
dominoSLEV6
Postby WTF?? » Thu Mar 30, 2006 11:16 pm
if youre not lowered, you have nothing to worry about... even if you ARE lowered, nothing to worry... itll fit
tires, go for 225/40/18
Retired... its been fun Image
WTF??
Postby TRD MCV20L » Fri Mar 31, 2006 12:36 am
225/40/18 would be the most common. However I like a wider tire so I would personally go with a 235/40/18 :D
TRD MCV20L
Postby SolaraBlue » Fri Mar 31, 2006 10:22 am
what rims were you thinking about buying? good luck, everything should work out fine.
Postby Omes01SLE » Sat Apr 01, 2006 1:00 pm
I have an opportunity to pick up some brand new Toyo Proxes T1-S tires at a good price, but they are 225/35/18 instead of the 225/40/18.
I don't plan on lowering the car anytime soon, do you think the 35 vs. 40 will leave too much of a wheel well gap?
Omes01SLE
