SolaraGuy.com • View topic - s/c installation
s/c installation
s/c installation
Postby krook » Fri Jan 31, 2003 6:43 pm
anyone ever try to do this install on your own? the instructions look...somewhat easy to understand. . . :o is it difficult to do if you are not too mechanically inclined?
krook
Postby Yanks0114 » Fri Jan 31, 2003 7:09 pm
From what I remember there are guys from teamsc3.com that have done it themselves and its not that bad but you need atleast two people and atleast a day
Postby Luc » Fri Jan 31, 2003 11:03 pm
It isn't too intimidating of a task if you want to tackle on. It took me and a friend about 10 hours working at a easy pace, while getting food in between. I kept track of all the parts that were taken off, so I know which ones to reuse again when called for. You'll definitely need a 3/8" torque wrench to set the proper tensions on all the nuts and bolts. Having a friend as a second pair of eyes really helps out. I felt the instant boost right afterwards, when we went out for a drive on the expressway. I wasn't mechanically inclined at first, but after reading up my Haynes and installing my suspension (and thereafter 2 other owners), the S/C would be another great learning experience. The installation manual is very adequate for DIYers, only part I was confused is the vacuum hose connections, that was only because I couldn't see straight after having spending most of day installing the S/C.
Luc
1998 S/C'd 1MZ-FE A/T
Luc
Postby ICUFG » Fri Jan 31, 2003 11:32 pm
I did it by myself, if you have the right tools and PATIENCE you will have no problem as long as that you are a little mechanically inclined.
ICUFG
Postby STR8PYP » Wed Feb 05, 2003 11:52 am
I've done 4 SC installs and it's a pretty straight forward job, but you'll need the right tools. The instructions can be pretty cryptic, especially the vacuum hose diagram, and some of the parts don't install like they are described in the instructions. If anyone is in Southern California I can do the install for you at a reasonable price.
SC
STR8PYP
Postby happy_aggies » Wed Feb 05, 2003 12:15 pm
:o Steve?
SC
happy_aggies
Postby STR8PYP » Wed Feb 05, 2003 1:11 pm
happy_aggies wrote::o Steve?
:) Wassup Arief!
SC
STR8PYP
