SolaraGuy.com • View topic - extended warranty and s/c
Postby David9862 » Sat Feb 01, 2003 1:25 pm
I currently have the 7 year 75,000 mi bumper to bumper extended warranty on my 02 solara with $0.00 deductible and my question is will the s/c void the warranty in any way? And how about the eibach/tokico combo?
Thanks
David9862
Postby DavPak » Sat Feb 01, 2003 8:04 pm
if your s/c was purchased brand new and installed by a toyota technician, your powertrain warranty is still intact. however, since your tokico/eibach setup is not made by toyota (or the TRD bilsteins) then some portions of your warranty will not be honored. basically anything suspension related.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Luc » Sat Feb 01, 2003 10:10 pm
It's also dependent on the dealer. I had some bozos install my Eibach springs before, and they caused my passenger rear speed sensor to malfunction. Luckily, my dealer replaced it for free under warranty when I took it in.
Luc
1998 S/C'd 1MZ-FE A/T
Luc
Postby David9862 » Sat Feb 01, 2003 10:38 pm
So if I buy the s/c from the dealer and have them install it then I should not have any problems with the waranty right? Don't want to waste that free extended warranty and since I drive less than 10,000 miles a year that thing will be good for another 6 years.
David9862
Answer
Postby JMSinMaryland » Sun Feb 02, 2003 11:10 am
You can get your dealership elsewhere as long as it's brand new (check kinderhooktoyota.com, toyotaparts4u.com, and partznet.com for best prices on S/C). If Toyota installs this (install from $350-$500) then your factory warranty is intact, hope this helps). Jon.
JMSinMaryland
Postby DavPak » Mon Feb 03, 2003 7:09 am
David9862 wrote:So if I buy the s/c from the dealer and have them install it then I should not have any problems with the waranty right?
correct. i've talked to 2 toyota reps about this and they both assured me the warranty will still be intact.
DavPak
Postby Jai_Jai_Binks » Tue Feb 04, 2003 10:03 am
Don't know about upgrading pully's and how that affects or voids your warranty, but i agree with people on top! So you might want to reconsider upgrading pulley after your s/c install!
Postby Yanks0114 » Tue Feb 04, 2003 12:50 pm
jhbhatia wrote:Don't know about upgrading pully's and how that affects or voids your warranty, but i agree with people on top! So you might want to reconsider upgrading pulley after your s/c install!
95% of the Toyota techs would not even know how to spot a smaller pulley. The pulleyboys pulley can be had in black which is the color of the 3.2" stock one. How are they gunna tell difference of .3" without a ruler. Plus its a pretty easy mod to remove
Postby DavPak » Tue Feb 04, 2003 1:53 pm
yanks0114 wrote:95% of the Toyota techs would not even know how to spot a smaller pulley. The pulleyboys pulley can be had in black which is the color of the 3.2" stock one. How are they gunna tell difference of .3" without a ruler. Plus its a pretty easy mod to remove
if they look for it, it'll be easy to tell since all toyota parts are marked as genuine toyota parts. but like i said, that's if they look for it. technically speaking though, an upgraded pulley does void the warranty, but yanks is right, 95% of techs wouldn't notice it.
DavPak
