SolaraGuy.com • View topic - For those who have blown Knock sensors
Postby lazyboyz69 » Mon Apr 17, 2006 1:04 pm
I was wondering guys, what kind of spark plugs did you have in your car when your knock sensors went off?
I had IK22 and i think it didn't go off, then i switched to stock ones, then it went off, running at 6lbs with no mods besides fuel pump.
well i'll be... i've been running on 4lbs.... all this time, i thought i was running on 6lbs...
lazyboyz69
Postby Ian » Mon Apr 17, 2006 7:14 pm
You have to get Jim's fuel mod, which is a higher flow fuel filter and seperate fuel lines to the fuel rails. There are several detailed threads on this. You should be fine after installing that.
Ian
