SolaraGuy.com • View topic - Fuel Delivery System?
Postby LifeguardSLE V6 » Mon Feb 03, 2003 9:29 pm
Is this a good idea? I'm hoping they will either increase gas mileage, or increase horsepower. http://www.adventon.com/acb/showprod.cfm?&DID=24&CATID=68&ObjectGroup_ID=1613
1999 Solara SLE......Lowered courtesy of Eibach and Tokico.
I put the PRO in procrastination!
LifeguardSLE V6
Postby cdssolara » Tue Feb 04, 2003 1:32 am
I don't think it will do you much good on it's own. If you have a supercharger with a small pulley and find you are running lean, an upgraded fuel pressure regulator and bigger injectors will help remedy that. Depending on how much boost you're running, you might have to do some additional modifications to keep your engine from blowing up.
cdssolara
