SolaraGuy.com • View topic - Steel Brake Lines.
Steel Brake Lines.
Steel Brake Lines.
Postby DrakkkarDarkbladE » Fri Apr 21, 2006 1:01 pm
Can some one please tell me which ones I have to buy for the front and rear from here:http://www.andysautosport.com/product/brakes/brake_lines?_v=vmd00415. If you know a better place please do tell.
Thanks in advance.
2002 SLE V6
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
DrakkkarDarkbladE
Postby Sap Z » Fri Apr 21, 2006 1:59 pm
have u tried tire rack? i mite be totally off..sorry if i am.
SapZ
V6 SE DWP
Sap Z
Postby purestyl3z » Fri Apr 21, 2006 3:17 pm
i believe the answer to your question depends on the setup of your car...
though i haven't had experience with the "wilwood" brand, the replacement brake lines typically follow the same routing as the stock brake lines. in the case of the products you are considering, "wilwood engineering" does not manufacture a specific brake line kit for the solara; thus, it would be necessary for you to measure the distance (including some angles) needed to custom cut them and ship to you. i'm inferring that the "flexlines" described in the wilwood products mean you'll be able to make some minor modifications to the lines yourself (as is the case with most brake lines). if you are lowered, you'll most likely have to modify attachments brackets for the strut. you should make sure that the lines are not touching any part of the suspension or drive train. in addition, if you have disc brakes on both front & rear, then the distances for them should be the same...
secondly, i wouldn't order from andy's auto sport... and i am only saying this from several first-hand experiences that have been nothing short of a nightmare... i would also recommend getting rotora's brake lines instead (you'll be able to find new ones on ebay shipped for ~$25-30)... those are the ones that came with my big brake kit http://www.rotora.com/press%20release/SOLARA.pdf...
finally, to answer your question on which on to get, i believe mine was similar to the last one on the first page (19 - f/m)... anywayz, good luck!
purestyl3z
Postby krook » Fri Apr 21, 2006 3:32 pm
just go to tirerack.com. i JUST ordered Goodridge SS brake lines from them (in a kit of 4) specifically designed for the Solara and i installed them.
they work great! the kit costs about $130.00
krook
Postby DrakkkarDarkbladE » Fri Apr 28, 2006 11:45 am
I could not find anything at tiretrack about break lines. What year is your Solara? Maibe you can give me the link?
thanks..
2002 SLE V6
DrakkkarDarkbladE
Postby Paladin06Greg » Fri Apr 28, 2006 1:36 pm
Paladin06Greg
Torqued Solara
Torqued Solara
Postby hskrsolara » Sun May 07, 2006 10:15 pm
^^are you using the stillen lines Greg? how do you like them?
hskrsolara
Postby Paladin06Greg » Mon May 08, 2006 4:05 am
They're are just fine.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Nodrogkam » Mon May 08, 2006 6:50 am
just curious, when you change the brake lines, is the fluid going to gush out everywhere? i just want to know so i can be sure to have the area well prepared for a mess.
1998 Camry XLE V6
My Car Domain
Nodrogkam
Postby SleeperSolara » Mon May 08, 2006 7:34 am
Nodrogkam wrote:just curious, when you change the brake lines, is the fluid going to gush out everywhere? i just want to know so i can be sure to have the area well prepared for a mess.
Yeah i think so, so you have to be quick like a rabbit to change them.
Actaully get a bucket and then open the old hose and put the new one on there, and your will have to bleed the new ones.
Postby krook » Mon May 08, 2006 12:15 pm
it doesn't really GUSH out, but you do have to be quick. after changing one line, you'll figure out which way is the easiest for you without having to lose too much oil. the best way i found was to remove the OEM rubber brake hose from the metal brake line FIRST. there's a "U" bracket holding the rubber hose in place, so you're gonna want to remove that first since it's a bitch to get out. with a 10mm flare wrench loosen the nut that connects the rubber hose to metal line on the car. at this point, GET YOUR NEW BRAKE LINE READY. pop out the OEM rubber hose and quickly replace your new line; flare wrench it on, and put the "U" bracket back. good luck with that as it's also a bitch to put back in. from there you'll be able to figure it out how to get it to the caliper. it's a 12mm or 14mm bolt holding the line to the caliper.
IF YOU'RE DOING THE FRONT BRAKE LINES, MAKE SURE YOU HAVE ENOUGH TRAVEL DISTANCE WHEN YOU TURN THE WHEEL EITHER DIRECTION! i snapped one of my lines during the install because i didn't have enough slack.
fair warning.
krook
Postby SPF 0 » Mon May 08, 2006 2:15 pm
Do steel brake lines really make that much quantifiable difference on a power braking equipped vehicle?
SPF 0
Postby krook » Mon May 08, 2006 4:24 pm
i can't really tell if it's the ss lines or the pads, but when i did my rotors, pads, and lines there was a noticible difference in stopping power and response.
krook
