SolaraGuy.com • View topic - help with rubbing issues
Postby supamouse09 » Wed May 03, 2006 1:24 pm
hi i have 5zigen hyper 5zr rims. they are 18x7.5 with a +35 offset. the rears are rubbing after i lowered it with the trd springs. the tires on it right now are 235/40R18. i need a recomendation on a place that rolls fenders and i maybe a different tire size. any one know a tire size that will help make the rubbing stop. i need new tires anyways. im a socal local. oh and i have a convertible so maybe because of the extra weight is causing the rubbing??
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Postby supamouse09 » Wed May 03, 2006 7:03 pm
bump...
supamouse09
Postby trdkamuri51o » Wed May 03, 2006 7:16 pm
there is your problem.. u have 235 wide tires.. they work on i belive 40+ offset.. without rubbing
i think 42 might be perfect..
rent a roller there are places that do it.. or drive your ass up here and do it at one of th meets... one of my friends is buying one and i plan on a rollin meet haha..
trdkamuri51o
Postby indiglosolara » Wed May 03, 2006 7:23 pm
Since you are in So. Cal. There is a place call The Wheel Supply.. They did mine and I have never had any problems. They do a good job and charge a good price..
Talk to Sander or Albert.. Tell them Kenny from Kallusive sent you and they should give you a good price.
www.Thewheelsupply.com
indiglosolara
Solara 2 xB
Solara 2 xB
Postby lazyboyz69 » Wed May 03, 2006 7:47 pm
try 225/35 or 225/40s that should do it
lazyboyz69
Postby ---CAMRAZY--- » Thu May 04, 2006 2:31 am
There is a place in whittier called modern auto off EAST of the 605 tell them Brian from SOCALLARA sent you and they will do it for about 50 bucks. Also ask for Frank.
