SolaraGuy.com • View topic - Tein coilovers..... FINALLY!
Postby sydemoid » Mon May 08, 2006 8:36 am
And all I have to say is WOW!!!!!!!!!!!
Im happy I waited!
The response is nuts.
Check it out:
http://www.imagestation.com/album/pictu ... 2106592078
sydemoid
Postby xavier » Mon May 08, 2006 9:08 am
so Tein has coilovers for a solara? Hmm. I'll have to check out their page. Looks good
xavier
Postby DatSRBoi » Mon May 08, 2006 9:10 am
Dang. makes me want to see my tien/tokico setup for one. Cost way too much of my buget.
Postby AznDragonV » Mon May 08, 2006 9:48 am
if u use coilovers and u get the tokico struts...will it still be a bumpy ride?
Looks nice!
AznDragonV
Postby gone » Mon May 08, 2006 9:57 am
Dio! Like I wrote before, looks hot.One of the best lookin Solara's reppin NYC! Watch out for those pot holes..lol.Keep doin ya thangggg
gone
Postby cklinh » Mon May 08, 2006 10:01 am
AznDragonV wrote:if u use coilovers and u get the tokico struts...will it still be a bumpy ride?
Looks nice!
Coilovers are a strut/spring combo... you wouldn't need another strut... (unless you're saying something that I'm not understanding)
cklinh
Postby krook » Mon May 08, 2006 12:22 pm
coilovers are a complete suspension setup. pfffffff....newbies. :p
krook
Postby TheTamago » Mon May 08, 2006 1:03 pm
http://www.solaraguy.org/viewtopic.php? ... highlight=
Some ppl gotta do some research as well lol. How low was your drop? The shop dropped mine to 1.5" all around. I might drop it another 0.25" or 0.50" if its possible depending on the possible height setting feasible. But have fun breaking the Tein SS's in! Wut setting are your fronts and rears at? I know my fronts are @ 4th click about from hardest on the dampers.
FYI= Don't call a coilover a Spring/Strut Combo :P The Strut is far more complex which is called the damper that can set the compression rate and ride height. A Regular strut only relies on the factory set compression rate and the bumper stomp which allows only so much of a 1 time setting change.
And also, Simple Car Tech Formula Coilovers > Strut/Spring Combo
Every D1 Driftcar uses Coilovers. For other racing events I don't know since I only like D1 but theres a high guarantee that most cars sport coilovers!
Small lil edit. Some coilovers have a electronic damper controller which allows for the most easiest settings without needing to pop open the hood or a couple panels to get to the damper setting knob. Saddly, the Solara Tein SS's isn't applicable, but when i last read I think the Celica Tein SS's were applicable for the electronic controller. Beat the lame Strut/Spring ppl to the ground!! lol :evilbat:
TheTamago
Postby GReddySetGO » Mon May 08, 2006 2:39 pm
Tein has been making coilovers for the first gen Solara for a long time! Even the Gen2 model has been out for like a year or so now.
Coilovers will always be far superiour to any spring/shock combo you can get. And as far as I know, all the JGTC, D1, etc pro race cars use coilovers only.
I use Tein coilovers on my track car and they are absolutely amazing! If anyone needs Tein, come to me ;) All models for all Solara, in stock!
Danny
AIM: GReddy EVO Si
Forced Fed @ 20 psi
GReddySetGO
Postby RJ@UPFD » Mon May 08, 2006 7:05 pm
Any looking for TEIN Products hit me up...I can match and most times beat any deal you can find.
And for those of you on a budget I can get Tokico Struts.
Later
RJ
I AM NOW WORKING FROM HOME...
Phone:714-901-8343
Mobile: 714-717-2068
Email: RJ2004OC@hotmail.com
RJ@UPFD
Postby sydemoid » Mon May 08, 2006 9:03 pm
Thank you everybody!
Im proud of my baby... lmao
I think Im about 4th click from stiffest, the drop was done at one inch from the bottom of the threading.. so if you do your math, its about a 2 inch drop up front, and 2 in the rear.
Potholes?.... Ms. Keys, I will watch out, but ummmm...... the ride quality is better than stock, due to its stiffness, but it has a lot of forgiving attributes.
You know where the Cross Island parkway splits to the Whitestone bridge/ 678 heading towards Grand Central Parkway?.....
Well, I took that turn towards GCP @ 80mph.... didnt even break a sweat, and no tire squeal. :evilbat:
Wanna race me now Toyochic?... lmao thanx 4 da email ;)
Oh yeah, newbies....
(beating a dead horse.. but ok!)
Coilover suspension is a complete setup, adjustable struts, with adjustable spring perches, that allows you as a driver to adjust the general behavior of your vehicle, to suit the needs of daily/track driving.
I know Ground control sells a coilover spring set, that is meant to be used with tokico shocks, but I would invest in either Tein, or JIC, and save myself the headache.
Oh yeah, most of you guys get to see the IS300 rims, with newly mounted Yokohama AVS ES100's 215/45/w17
VERY NICE!!!!
sydemoid
Postby TRD MCV20L » Tue May 09, 2006 1:21 am
What made you go with the Tein over the JIC's? I'm debating between the two.
TRD MCV20L
Postby AznDragonV » Tue May 09, 2006 1:36 pm
Looks nice!
haha oops yea i jus remembered...i was thinking of something else...sry
AznDragonV
Postby Solorange » Tue May 09, 2006 1:42 pm
Hey looks great. Im def diggin the Is rims too! What rotors are you running. They look bigger than stock, but I noticed your still using the stock calipers. P.S. Paint your calipers.
Postby GReddySetGO » Tue May 09, 2006 2:00 pm
TRD MCV20L wrote:What made you go with the Tein over the JIC's? I'm debating between the two.
What activities do you use your car for mostly? (going to work/school, shows, drag, ciruit, etc)
Danny
AIM: GReddy EVO Si
Forced Fed @ 20 psi
GReddySetGO
