SolaraGuy.com • View topic - Pro Steet Kit
Pro Steet Kit
Pro Steet Kit
Postby Akfahad » Sat Feb 08, 2003 12:11 pm
Anybody have some insight to the Pro Street Kit, by Jacobs Electronics? Check it out...
http://www.jacobselectronics.com
or
http://www.burnabyauto.com
Postby CrazyCraig » Sat Feb 08, 2003 3:35 pm
A high end electronic ignition is a waste of your $$$$$ as they are designed with racing in mind. They are generally used for high rpm engines in cases where the factory ignition cannot supply enough spark for the application, or in larger inefficient engines to increase the amount of fuel burnt up in the combustion chamber.
CrazyCraig
CrazyCraig
Postby Yanks0114 » Sat Feb 08, 2003 4:07 pm
Toyota has a very good stock ignition system. You could upgrade your wires and that would help a little, but the toyota TDI is a great setup.
Postby Guest » Sun Feb 09, 2003 9:18 am
So would you consider the Ice Pak a waste of money too or is that somethig completely different?
Guest
