SolaraGuy.com • View topic - Wiring A/F ratio Gauge
Postby Sleeper » Wed May 10, 2006 11:12 am
Can anyone tell me how to properly wiring an air fuel ratio gauge, without setting off the O2 sensor? I installed mine and it made my front bank O2 sensor to malfunction. I know that indiglo solara told me there was a specific way of doing it. Now I bought another one and do not wish to mess this one up to.
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby GReddySetGO » Wed May 10, 2006 12:46 pm
What kinda gauge?
Danny
AIM: GReddy EVO Si
Forced Fed @ 20 psi
GReddySetGO
Postby Sleeper » Wed May 10, 2006 4:07 pm
its an Autometer Air/Fuel Ratio gauges - Electrical not mechanical
SLEEPER...
Sleeper
Postby GReddySetGO » Thu May 11, 2006 2:30 pm
Does the Solara use a 4-wire O2 sensor? Usually just tap the blue wire from the O2 for an Auto Meter AF gauge. That's the sender wire. You are supposed to TAP this, not cut it.
Also just FYI, Auto Meter AF gauge does not tell you anything usefull. The stock O2 sensor is whats known as a narrowband O2 sensor. It only reads lean or rich and switches back between the two. So your Auto Meter guage is just going to light up and go back and forth as you drive. It will probably just sit on lean when at idle.
If are using this gauge to monitor your AF for tuning, or engine safety purposes, then I would suggest getting a wideband AF gauge. A wideband sensor can read the actual ratio (11:1, 14.7:1, etc) and give you the most accurate reading for tuning and other purposes.
If you want a gauge with pretty lights and looks cool, and that all you want to use it for, then by all means, keep the Auto Meter and hook it up.
Danny
AIM: GReddy EVO Si
Forced Fed @ 20 psi
GReddySetGO
Postby krook » Sat Sep 23, 2006 5:53 pm
what's a good wideband A/F gauge???
can i just moniter air/fuel ratio if i get an S-AFC neo???
krook
Postby Ford_Fixorrepairdaily » Sat Sep 23, 2006 6:00 pm
krook wrote:what's a good wideband A/F gauge???
You can monitor the A/f with the S-AFC. Usually wideband's are quite expensive, not really worth it unless youre gonna do some serious tuning, but theres bunch on www.urdusa.com
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
