SolaraGuy.com • View topic - Alarm..i need one,WHY????? door locks auto-open???
Postby LatinUSMC » Tue May 16, 2006 7:01 am
i need an alarm(under $150)
cuz,
my electric locks are tripin and seem to re-open when i press on the dealership stock lock button.
.anybody have this problem?????
LatinUSMC
Postby theprodigy79 » Tue May 16, 2006 7:44 am
I'm not sure if I am understanding exactly what you are saying, the "dealership stock lock button" portion is what's throwing me off... but I would start by checking your fuses. My grandmother had an issue in her Chrysler LeBaron where she would lock it using the electric lock button on the arm rest and it and it would unlock immediately... It was a really whacked out problem, but it turned out to be a blown fuse...
theprodigy79
Postby lilm » Tue May 16, 2006 11:52 am
mine unlocks when i turn on the car or put it in gear :)
dude you are seriously ruining disney for me.......
lilm
Re: Alarm..i need one,WHY????? door locks auto-open???
Postby krook » Tue May 16, 2006 12:02 pm
LatinUSMC wrote:i need an alarm(under $150)
cuz,
you're not going to find a reputable alarm for under $150. unless you can find a place that installs DEI products for that cheap. (DEI/Directed Electronics = Makers of Viper)
this is what i tell customers when they're having this problem:
"Getting an aftermarket alarm will not solve whatever problems you're having with your OEM system. If your locks don't work, the alarm won't make it work for you; the aftermarket system will duplicate whatever the switch and/or the OEM system is doing."
get your locks fixed. it sounds like a ground in the negative trigger door wire or something might be wrong with the ignition wire to the OEM system. (you'll notice that your locks will re-open if your key is in the ignition)
krook
alarm/locks
Postby LatinUSMC » Tue May 16, 2006 5:05 pm
to clear it up...when i press the lock button on the door or on the stock remote(the one i got at the dealership) it locks then imediatelly unlocks and stays unlocked so i can leave anything valuable....... :evil:
LatinUSMC
Postby krook » Tue May 16, 2006 5:28 pm
does it work from the outside? what i mean is can you lock the car from the driver's door with the key and door keyhole?
krook
radio
Postby LatinUSMC » Tue May 16, 2006 5:30 pm
no , even with the key inserted from the outside it locks and immediately unlocks
LatinUSMC
Postby MCOjerry » Tue May 16, 2006 6:04 pm
Sounds like it could also be some kind of cuputer glitch, like it's sensing you still have your key in the ignition. (that's the lock out feature)
locks
Postby LatinUSMC » Tue May 16, 2006 7:47 pm
il check the fuses
LatinUSMC
Postby PXLpainter » Tue May 16, 2006 8:33 pm
lilm111 wrote:dude you are seriously ruining disney for me.......
ROFLOL!!! :lol: :lol: :lol:
My thoughts EXACTLY!! :D
Postby theprodigy79 » Tue May 16, 2006 8:58 pm
Haha yeah... I had to have a bit of fun with that...
theprodigy79
fuses???
Postby LatinUSMC » Wed May 17, 2006 9:56 am
:evilbat: i didnt find the fuse and now the dors are locking as if nothing was wrong???????????????? go figure it must of been loose wires...dunno :o
LatinUSMC
Postby krook » Wed May 17, 2006 11:51 am
i'd have the alarm checked if you don't want that problem to come back. your Ignition connection to the alarm is probably catching 12v somewhere, which would probably mean your alarm would need to be replaced/disconnected.
krook
Postby NeFaRiOuS_SLE » Thu May 18, 2006 9:14 am
HAHAHAHAHA want me to ruin it further? ***NOT WORK SAFE***
http://www.disneypornland.com/
