SolaraGuy.com • View topic - wheel locks?
wheel locks?
wheel locks?
Postby Sap Z » Mon May 22, 2006 4:28 pm
what are the different kinds of wheel locks for the gen 1? wat is the size i should be looking for?
this is what i found on ebay
http://cgi.ebay.com/ebaymotors/Tuner-Lu ... dZViewItem
it says 'this is not a tuner lock"
whats the difference between a normal lock and a tuner lock?
thanks guys
SapZ
V6 SE DWP
Sap Z
Difference
Postby JMSinMaryland » Mon May 22, 2006 4:39 pm
I have 4 splinedrive lugnuts and 1 McGuard wheel lock on each wheel. The splinedrive have a special tool that needs to go on whereas the McGuard has a key that has to fit in. The splinedrive by itself would protect against most thieves but the McGuard is just in case. Jon.
JMSinMaryland
Postby Russian Mafia » Mon May 22, 2006 5:07 pm
i dont think there a difference, just get ones that dont stand out too much
My wheels actually came with wheel locks (maybe those are tuner locks) 5 for each wheel. Otherwise it would be pretty ungly to have stock ones, cuz my new wheels dont have center cover part (or whatever it's called).
'01 Solara SE V6, 5 speed
Russian Mafia
Postby SolaraBlue » Mon May 22, 2006 5:10 pm
^^ there is definitely a difference..... size/style etc... all make a difference. you cant just go out and buy a random set and throw em on.
Re: Difference
Postby Russian Mafia » Mon May 22, 2006 5:18 pm
JMSinMaryland wrote:I have 4 splinedrive lugnuts and 1 McGuard wheel lock on each wheel. The splinedrive have a special tool that needs to go on whereas the McGuard has a key that has to fit in. The splinedrive by itself would protect against most thieves but the McGuard is just in case. Jon.
i missed this post...this is what i have, too
Russian Mafia
Postby camry_101 » Mon May 22, 2006 5:19 pm
well normal locks can be takin off by anyone and tuners can not because they come with a special key that only you have so only you can open it!!!!
2007 Ninja 500R stock
camry_101
Postby Solorange » Wed May 24, 2006 1:45 pm
Our spline guards the kind that have a special socket adaptor? Cause I think thats what I have. They would stop most people but, a pipe wrench or a channel locks could probably get them off. It would be hard though cause these lug nuts sit pretty far inside the wheel and it would be hard to get a tool around it. They would probably do more damage to wheel.
Users browsing this forum: Google [Bot] and 55 guests
