SolaraGuy.com • View topic - 40's or 45's?
40's or 45's?
40's or 45's?
Postby blaK » Thu May 25, 2006 1:24 am
Sup guyz,
I bought tein springs and tokico struts and the rims I'm getting is 18-7.5 but the recommended size profile is 40's. I want 45's for a softer ride if possible. Will I have wheel well problems?
Just bought mine, it's a 01 SLE.
Is it worth getting injen intake when I already bought k&n air filter? That much of a difference? for $200
I already changed the head unit and jbl's for a premier and boston speakers with JL audio amp and sub. HID's are next.
Thank's guyz, glad to be here!!
blaK
Re: 40's or 45's?
Postby WTF?? » Thu May 25, 2006 1:42 am
blaK wrote:I bought tein springs and tokico struts and the rims I'm getting is 18-7.5 but the recommended size profile is 40's. I want 45's for a softer ride if possible. Will I have wheel well problems?
stick to 225/40/18... most members here wont have tire rubbing issues with that set up... whats your offset on the rims? should be around +42mm..... hoonestly you wont notice a softer difference by going to 45's.... straight truth
blaK wrote:Is it worth getting injen intake when I already bought k&n air filter? That much of a difference? for $200
k&n filter will do just fine... but in the long run if you decide to do more performance, the injen will compensate for what youll be doing
blaK wrote:I already changed the head unit and jbl's for a premier and boston speakers with JL audio amp and sub. HID's are next.
glad to hear your enjoying your modding
Retired... its been fun Image
WTF??
Postby blaK » Thu May 25, 2006 2:39 am
KooL thx, offset comes in 35 and 45 for these rims and I want the 35's.
blaK
Postby WTF?? » Thu May 25, 2006 11:41 am
If youre doing 35 offset, you may have to roll/cut your rear fenders since itll stick out a little further. With added weight from passengers and your lowered suspension, going over bumps you will rub
WTF??
Postby blaK » Thu May 25, 2006 8:08 pm
I went 40's, didn't want the headache of worrying. Toyo-Proxes 4.
blaK
Postby SolaraBlue » Thu May 25, 2006 9:01 pm
listen to WTF?? he knows what he's talkin about. and welcome!!! :D
post some pix when you get the wheels/suspension installed. what wheels are you going with anyway?
Postby blaK » Fri May 26, 2006 6:33 am
100%. ThX will do.
http://www.wheelmax.com/product.asp?ProdId=11039
Is there a better site for HID's?
http://gohid.com/hid-automobile-table_5101.html
The reason I didn't go turbo, because the car is still under warrenty.
It only has 35k miles and I'm good for now, just want it ride better.
blaK
Postby SolaraBlue » Fri May 26, 2006 9:00 am
those wheels should look real good. gonna be a bitch to clean though :D
Postby indiglosolara » Fri May 26, 2006 9:14 am
Here a table you can use.
http://www.rims-n-tires.com/info_specs.jsp
one side you put your stock tires and other side you can put your new tire specs you want and it will give you detailed information wheater or not it will match stock size.
They also have a offset feature for us guys that want to go with wider wheels.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby blaK » Sat May 27, 2006 7:10 pm
That table is awesome, thx bro. But the guy I spoke to said the lower the offset # the farther out the wheel will be but not according the table.
I'll see when the wheels come in:)
blaK
Postby Solorange » Mon May 29, 2006 7:02 pm
i think with 45series you will have a greater chance rubbing the fenders, cause I sometimes rub with 40's. But then again it depends mainly on your offset.
Postby blaK » Wed May 31, 2006 1:43 am
Did anyone go 8.5 for rim width?
blaK
Postby Solorange » Wed May 31, 2006 2:18 pm
im running 7.5, sorry.
