SolaraGuy.com • View topic - Would it be bad......
Postby SleeperSolara » Sun Jun 04, 2006 4:02 pm
If we were to block off the EGR port on the 1MZFE Solara.
Read about a block off plate for the MR2 turbo.
Cause the EGR valve lets some of the exhaust hot gas back into the intake manifold, to reduce detonation.
But woudl that be a bad idea to block it off????
Cause you don't want hot air in the intake manifold, right????
Postby NeFaRiOuS_SLE » Sun Jun 04, 2006 5:04 pm
The most basic problem would be the CEL light turning on, but I don't know if it causes anything else to happen.
Postby Midias » Sun Jun 04, 2006 8:07 pm
I remember doing it on my Accord. It had two ports one that opened and closed and a straight through path. So I made a gasket that bloacked off only 1 port. I haven looked at the Solara yet.
Postby SleeperSolara » Mon Jun 05, 2006 4:24 am
Midias wrote:I remember doing it on my Accord. It had two ports one that opened and closed and a straight through path. So I made a gasket that bloacked off only 1 port. I haven looked at the Solara yet.
Well looked in the Haynes book, and it leads to a port near the rear headers......
Postby Fletch » Mon Jun 05, 2006 8:26 am
Besides plates for the intake and exhaust manifolds, you need a way to trick the EGR valve or it won't run/idle correctly. My bet is any gains are not worth the trouble. A turbo 1mz would probably have a stand alone A/F system and exhaust so it makes more sense to just get rid of the EGR stuff.
2006 Legacy GT spec.B
Fletch
Users browsing this forum: Google [Bot] and 55 guests
