SolaraGuy.com • View topic - polished header pics and custom grill
Postby Danny » Wed Feb 12, 2003 8:19 pm
hey guys i just got the new headers and y-pipe installed, the sound is amazingly different, and the performance is definatly there , email for pics
krystalblue18@yahoo.com
Danny
Postby Peter » Wed Feb 12, 2003 9:13 pm
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby 808Camry » Wed Feb 12, 2003 10:04 pm
how did the install go?
808Camry
howd the install go ??
Postby Danny » Wed Feb 12, 2003 10:10 pm
3-4 hours when smooth you must have s-afc to properly run this setup, or you will run extremely lean, and the knock sensors will retard the timing severly.
Danny
Please explain
Postby JMSinMaryland » Wed Feb 12, 2003 10:13 pm
Running a stock 4psi pulley and headers/y-pipe/exhaust how could the headers/y-pipe change the A/F so drastically as to warrant the S-AFC? If this is true Im going to have to wait 50,000 more miles till my warranty is over before I get the headers. Jon.
JMSinMaryland
Possibility
Postby JMSinMaryland » Wed Feb 12, 2003 10:16 pm
Probably your Injen is helping it to lean out. I'd like to see results on the aforementioned 4psi S/Cd Solara with the headers/y-pipe and cat-back. Probably it wouldn't run lean. Jon.
JMSinMaryland
Postby ICrazyChrisI » Wed Feb 12, 2003 10:31 pm
The injen intake causes the 1mz to run rich...
ICrazyChrisI
Postby happy_aggies » Thu Feb 13, 2003 8:41 am
Danny,
How much the headers and Y-pipe cost you?
Do you have to give your own Y-pipe and headers?
happy_aggies
Postby EricSol » Thu Feb 13, 2003 8:31 pm
Generaly when you free up the intake or exhaust it leans out the mixture. Ron has a y-pipe and intake with 5.5psi and Area51 needed to use his Afc to take out fuel where as my car needed the Afc to add fuel. Bottom line is every car is different and running lean with a s/c is bad. I'm a firm believer in at least checking your a/f mixture to see where your at.
Eric
ICrazyChrisI wrote:The injen intake causes the 1mz to run rich...
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Re: Possibility
Postby Flipside909 » Fri Feb 14, 2003 10:43 pm
JMSinMaryland wrote:Probably your Injen is helping it to lean out. I'd like to see results on the aforementioned 4psi S/Cd Solara with the headers/y-pipe and cat-back. Probably it wouldn't run lean. Jon.
No, it will do the opposite on an N/A. The MAF will read more flow therefore compensating my richening the mixture.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
