SolaraGuy.com • View topic - throttle body spacer mishap
Postby blakey2007 » Wed Jun 28, 2006 11:53 am
ok guys i got my spacer installed and what a b**** it was and i get into my car and turn it on and as soon as it turns over it shuts off i took it off and it runs fine again whats wrong i checked all my connections
130 top speed jenson 7" flip up dvd, 2 10" kicker comps 150.2 kicker amp shaven emblems coming soon tb spacer and injen sri & painting grill black
blakey2007
Postby bassthrive » Wed Jun 28, 2006 3:08 pm
You sure the MAF sensor isnt disconnected?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Midias » Wed Jun 28, 2006 4:05 pm
dbl check the maf and all connectors as well as the intake rubber connectors
I had no problems instant start up noo idle issues ect
yeah
Postby blakey2007 » Thu Jun 29, 2006 9:01 am
yeah i checked all my connections. this is going to sound really like a newbie but the maf is behind the intake right
blakey2007
Postby Midias » Thu Jun 29, 2006 11:10 am
I need to know a few things did you take out the bottom studs and replace them with bolts of sizes recomended in the origional TB thread. Also did you use both gaskets.
Postby agent007 » Thu Jun 29, 2006 12:42 pm
midas does the HVS work and if so can you feel the difference...just noticed it in the pic and i remember seeing one on another page.
01 solara v6 se
trd kit, trd rims, trd suspension
greddy evo cat back
c/f hood
agent007
Postby Midias » Fri Jun 30, 2006 12:04 am
agent007 wrote:midas does the HVS work and if so can you feel the difference...just noticed it in the pic and i remember seeing one on another page.
check here
http://www.solaraguy.org/viewtopic.php?t=26210
yeah
Postby blakey2007 » Thu Jul 06, 2006 9:29 pm
yeah i used the 70 mm bolts and both gaskets i really havent had time lately to work on it anymore i guess i will just try it again
blakey2007
Postby blakey2007 » Thu Jul 06, 2006 9:30 pm
and i did take out the bottom bolts but do u need the throttle cord extender
blakey2007
Postby indiglosolara » Fri Jul 07, 2006 8:32 am
Did you installed the MAF sensor backwards...
It has happened to ppl in the pass. Try turning it around and see if that works.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Midias » Fri Jul 07, 2006 5:43 pm
blakey2007 wrote:and i did take out the bottom bolts but do u need the throttle cord extender
Did you install the injen at the same time (miss a vacume line backwards maf ect.)
No need for the throttle extender plate
it works
Postby blakey2007 » Tue Jul 11, 2006 2:30 pm
hey guys thanks for all your help i got the throttle body in and it works great. i can definately tell the difference. i will be updating with pictures soon.
blakey2007
Re: it works
Postby indiglosolara » Tue Jul 11, 2006 2:48 pm
blakey2007 wrote:hey guys thanks for all your help i got the throttle body in and it works great. i can definately tell the difference. i will be updating with pictures soon.
What was wrong before????
indiglosolara
Solara 2 xB
Solara 2 xB
Re: it works
Postby Midias » Tue Jul 11, 2006 5:17 pm
so what was the fix?
yeah
Postby blakey2007 » Wed Jul 12, 2006 8:21 pm
i checked my gaskets and one of them had been bent so that when i bolted it in it would bend so that a leak would be made in the intake. so i like just redid the install and made sure that a seal was made.
blakey2007
Users browsing this forum: Google [Bot] and 60 guests
