SolaraGuy.com • View topic - Front Sway Bar
Front Sway Bar
Front Sway Bar
Postby Sleeper » Mon Jul 03, 2006 3:30 pm
I just wanted to know if the WhiteLine Front SwayBar is a direct fit to the gen 1. If any one has it, how much better/or worse does the car handle in junction with the TRD RSB? Is there any other brand who makes Front swaybars?
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Also, does anyone know the proper size in the Whiteline catolog?
SLEEPER...
Sleeper
Postby MentatGom » Tue Jul 04, 2006 3:39 am
Yes, the whiteline swaybar is a swap in replacement, using stock hardware with the exception of new bushings. I have both front and rear whiteline bars and I prefer having both over just the rear. I have seen front swaybars from whiteline (24mm), addco (22mm), intrax (22mm).
MentatGom
Postby Sleeper » Tue Jul 04, 2006 10:49 pm
thanx for the info man, really appreciate it.
SLEEPER...
Sleeper
Postby SleeperSolara » Wed Jul 05, 2006 6:33 am
The TRD RSB, gives you more oversteer.
And wit a Whiteline FSB will give you more understeer.
If you have either one that is.
Now if you have them together the response will be equal.
The TRD RSB will ahve oversteer, but hte Whiteline FSB will equal out the TRD RSB.
