SolaraGuy.com • View topic - TB Spacer installed and tested on Red Knight
Postby trd4life » Tue Jul 04, 2006 3:24 pm
Installed the spacer since i got it for free so i figured what the hell i'll give it a try. Suprisingly i am seeing a significant increase in aiflow on the safc. With the Supra TT MAF i used to peak at about 51% airflow at WOT (the stock maf was maxed out and read 100% airflow), With the spacer installed i am now peaking at 71% airflow at WOT. I havent been back to the dyno, but 20% increase in airflow should be a good amount of HP. I like the whistling sound as well, i start to get into it and hear the whistling, then as i get full throttle the whistling sound is taken over by the s/c whine. it sure makes peoples heads turn when i go WOT.
My last trip to the dyno before the spacer was 279whp with the auto trans no nitrous. A significant increase over what i started with when i bought the car (250whp). I've done some port work on the lower intake and s/c. increased the size of the intake tube to 3.5",NGK iridiums, and some safc adjustments. The port work made a huuuugggeee difference.
later guys
I'll post some nitrous dynos and 1/4 mile times once i get the built trans back in there. I am currently running a stock auto so no nitrous for now
Postby Astro » Tue Jul 04, 2006 3:29 pm
Well, that's good news. I'll install my soon, maybe I finally do it this coming weekend.
Postby Midias » Wed Jul 05, 2006 12:37 pm
Good to hear I am glad to see factual positive results (to match my butt dyno) cannot wait to see dyno results.
Postby dominoSLEV6 » Wed Jul 05, 2006 12:55 pm
Damn, I didn't realize the airflow improved that much. That along with the y pipe idea you were talking about seem to be commonly overlooked areas where some decent power can be gained on our cars. Keep it up Gabe.
-chris
dominoSLEV6
Postby SleeperSolara » Wed Jul 05, 2006 1:06 pm
Wow Gabe, you test on the TB is good.
Can't wait to see the results.
Postby DatSRBoi » Wed Jul 05, 2006 1:10 pm
Yo Gabe, where you been bro?
WOuldnt increased airflow means more air which results on the car running lean with the SAFC unless retune?
spacer
Postby trd4life » Wed Jul 05, 2006 6:49 pm
Dat i added fuel up top with the safc to compensate.
If i can ever stop getting my ass in trouble with probation i'll be going to the race track to see what the car can do at this point.
Postby Paladin06Greg » Wed Jul 05, 2006 6:57 pm
Well I'm glad to hear the TB spacer I stuck my neck out for is worth the money. :lol:
No thanks necessary. 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Midias » Sun Jul 09, 2006 8:58 pm
Paladin06Greg wrote:Well I'm glad to hear the TB spacer I stuck my neck out for is worth the money. :lol:
ypu are the man 8)
