SolaraGuy.com • View topic - another RSB question
Postby Sap Z » Wed Jul 05, 2006 10:40 am
So i've done my share of reasearch on installation etc on the RSB since i'm getting mine maybe sometime next week (hurry Reggie! )
so..questions
1)i read a lot about ppl settign it on 'street' and then chaning it to track to get the feel'..or to get used to it.i dont understand what theere is to get used to. i mean..is it wrong to go to track right away? how is track diff from street?
2) does it have 2 or 3 settings?
3) so do i need to take the heat sheild off? i'm on stock suspension and muffler.
4) what comes in the box? does it come with grease and all the neccesary parts? or do i need to buy something?
thanks !
:angel:
SapZ
V6 SE DWP
Sap Z
Postby SleeperSolara » Wed Jul 05, 2006 11:09 am
1. I had it on "street" settin' and then switched to "track" cause didn't know. :oops:
2. 2 settin': "street" and "track".
3. No need to take off heat shield. Though it would be helpful to take off the muffler.
So you don't have to wrestle that much to get it in.
4. Contents of box: TRD RSB, instructions, 2x poly bushin', and some lube.
But i would just go buy some White Lithium Grease, so you can apply alot so it won't squeak so soon.
Let me know if you need any help.
Postby Hsakuragi » Wed Jul 05, 2006 11:09 am
2) 2 settings
3) No, you don't, but u need to puzzle out OEM SB.
4) It comes with everything you need, basically, sway bar, 2 bushings and some grease, I would suggest you get some telfon tape, wrap it over where the bushing is going to be.
Hsakuragi
Postby Sap Z » Thu Jul 06, 2006 8:56 am
thx
SapZ
V6 SE DWP
Sap Z
Postby Fletch » Fri Jul 07, 2006 2:40 am
Set it on track right away.
2006 Legacy GT spec.B
Fletch
Postby Whatever » Fri Jul 07, 2006 3:31 am
yup, set it on track right away.
Whatever
Postby HaliGuy69 » Tue Oct 17, 2006 5:38 pm
probably a stupid question but which one is the track setting? i installed mine into the hole closest to the end of the bar
HaliGuy69
Postby Nyyankees3511 » Tue Oct 17, 2006 6:24 pm
The track setting is the hole closer to the front of the car, in other words the hole thats NOT near the end of the bar.
Nyyankees3511
Postby CASTRO » Wed Oct 18, 2006 12:10 am
yep, i dont even know why they got two settings. If possible, i'd want it stiffer :D
CASTRO
Users browsing this forum: Google [Bot] and 48 guests
