SolaraGuy.com • View topic - Lowering Springs
Lowering Springs
Lowering Springs
Postby FLASH » Mon Feb 17, 2003 10:27 pm
I know this has been discussed a million times, but I couldn't find a simple answer to my question. On partznet.com they are selling TRD 1.25" Lowering Springs for some $240.00 Everyone who lowered their ride has also replaced the struts and done other such work. I was wondering if anythign else NEEDS to be done, or if I could just buy the springs, bring them to a mechanic/autobody and say "Put these on for me" Thanx
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Missay » Mon Feb 17, 2003 11:19 pm
ok..i guess i'll try to take a stab at this one in layman's terms since i have very little car knowledge :wink:
basically, you can have the place just put them in to lower the car..but it will but strain on your struts..so you'd eventually want to change the too...sooo..you can either put on just the springs and get struts later..or save yourself the headache and take care of it in one shot.
then there's the whole ideal eibach/tokico combo crap stuff..lol..you get the idea :)
Melissa
Missay
SolaraGuy Ambassador
Postby Peter » Mon Feb 17, 2003 11:32 pm
missay put it perfectly. i was gonna do that first too, i didnt feel like spending another 3-400 on struts after getting the springs, but i was convince by fellow members that doing it all at in one shot will make life easier. and the ride quality w/ aftermarket struts is a lot better. good luck w/ ur decision, im doing my install tomorrow. :D
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby cdssolara » Tue Feb 18, 2003 5:08 pm
Missay and Peter are correct. You can use your OE struts with lowering springs, but why would you want to? They will wear out quicker, so you'll end up replacing them, anyway. Also, the stock struts were not designed to work with lowering springs, so you won't get the intended performance out of your new springs. Also, regarding who can do the work; your best bet is to call a performance shop. When I called for quotes on this work, I got prices ranging from $200 to $600. You shouldn't have to pay more than low $200 range for this work, if the shop knows what they're doing. If they have to consult a guide to give you a quote, forget about it.
cdssolara
Postby Yanks0114 » Tue Feb 18, 2003 8:55 pm
very nicely put :D
BTW the true drop on the TRDs is about 1.6". They are the same as the eibachs which you can get for a lot cheaper :wink:
Postby Peter » Wed Feb 19, 2003 1:41 am
just installed mine today. it was pretty easy, the only reason it took me a while was because of the compressing. compressing springs suck! i suggest you do it yourself. feels a lot better when you're done and save yourself 200+
Visit Black Sheep
Peter
Postby krook » Wed Feb 19, 2003 8:26 pm
^ dang! much props peter! i know you borrowed your friend's spring compressor...but i was just wondering, how much one of those things would cost? and how difficult was the install?
krook
Postby Peter » Wed Feb 19, 2003 8:33 pm
you can rent them at autozone for 43 bux, and its just a deposit. you get it back when u return it, so its basically free. btw, check out pictures at my cardomain site. the link is in my sig.
as far as difficulty, it wasnt too bad. just gotta have the right tools. make sure you get a good torque wrench that can go as low at 5 and and high as 250. might be a little expensive, but its well worth it. you'll need it again in the future if you do a lot of DIY's like me. if u have questions, hit me up
Visit Black Sheep
Peter
hey peter
Postby xXsolaraXx » Thu Feb 20, 2003 4:52 pm
hey peter, ur ride looks sweet and low! hehe...btw...are you thinking about getting rims? cus that would complete ur look...nice job on the lowering DIY! L8r, moe :evilbat:
xXsolaraXx
Postby Peter » Fri Feb 21, 2003 2:00 am
yeah, im still deciding on 17 or 18 though....
Visit Black Sheep
Peter
Postby adam2562 » Fri Feb 21, 2003 6:58 am
$200-$600 i had my Tokico's put in and my intrax removed and put bak in with them.. and front and rear struts mounts and front and rear whiteline bars ... all dor $150 :D hehe god i love working at toyota!!
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby DavPak » Fri Feb 21, 2003 8:08 am
adam, what do you do there?
'02 Solara S/C'ed V6 5-spd
DavPak
