SolaraGuy.com • View topic - Going HID.
Going HID.
Going HID.
Postby Wang2k » Tue Jul 11, 2006 1:27 pm
Im going to try my hand at retroing a set of E46 M3 Bi-Xenons into my new headlights. I have no experience with any of this, but the only thing im really worried about is how to actually mount the projector in the housing, but ive got some ideas. Im gonna get shrouds as well. Ill post pics when im done. Should be hot..the gen 1 headlight should lend itself well to Bi-xenon. The gen 1.5 looks like it needs seperate projectors for high and low beams. Damn you astro...
Wang2k
Postby gasolara2002 » Tue Jul 11, 2006 2:08 pm
are you planning to use your high beams(if your car is a gen1)
If so you need to get infinity Q45 projectors they allow you high beams to function because the upper part of that projector has a high cut off line.
gasolara2002
Postby gasolara2002 » Tue Jul 11, 2006 2:16 pm
if it is a gen 1.5 nevermind my previous statement and listen to this one. Post pics when you get thru and keep everyone updated.
gasolara2002
Postby Wang2k » Tue Jul 11, 2006 2:17 pm
the e46 projectors have a high cutoff line or the Q45 ones do?
Wang2k
my car is a gen 1 i was going to put the E46 projectors in the stock location and use them for high beams and low.
Wang2k
Postby gasolara2002 » Tue Jul 11, 2006 2:31 pm
in that case you might want to get the Q45
gasolara2002
Postby gasolara2002 » Tue Jul 11, 2006 2:33 pm
the projector you have is just for low beams and that means you high beams will be useless
gasolara2002
i just want to help you out before it is too late because i really want to see this mod go right.
gasolara2002
Postby krawzyazn » Tue Jul 11, 2006 3:09 pm
you have bi-xenon from the e46 thats good enough
Postby ---CAMRAZY--- » Tue Jul 11, 2006 3:22 pm
gasolara2002 wrote:are you planning to use your high beams(if your car is a gen1)
Any BI-XENON could be used as Hi-Low beams. Go to hidplanet and research there, a lot of good info.
And for Wang2k, good luck man.
Postby gasolara2002 » Tue Jul 11, 2006 3:27 pm
i thought bmws used a separte bulb for the high beam
gasolara2002
Postby Astro » Tue Jul 11, 2006 3:31 pm
GL man, it's not easy!!!
Postby Wang2k » Tue Jul 11, 2006 3:36 pm
The projectors i posted have high and low beams. They are going to work fine. I know its not easy. Its gonna be a pain in the ass rigging up a way to aim them. Im telling u guys tho, i think i have a plan lol.
Im going to mount the projectors to a stiff rod that is centered where the stock bulb is supposed to go. Im hoping i can make this work because then the stock adjustment would work. Im not sure if i can pull this off but it sound like the easiest way. Any thoughts would be appreciated because nobody around here has a set of retrofitted lights i can look at to see how they mounted the projectors.
Wang2k
Postby gasolara2002 » Tue Jul 11, 2006 3:36 pm
here is the link. They are just low beams. Save yourself some time and just listen. Click or paste the link.
http://www.turnerautomotive.com/01_black_m3.htm
gasolara2002
Postby gasolara2002 » Tue Jul 11, 2006 3:38 pm
i really want you to do it right i am trying to warn you before it is too late.
gasolara2002
Users browsing this forum: Google [Bot] and 60 guests
