SolaraGuy.com • View topic - Ground Wire Kit Questions
Which route should I choose?
Big 3
3
60%
Ground Kit
2
40%
Total votes : 5
Postby SolaraGuy22 » Thu Jul 13, 2006 12:44 pm
I want to add more grounds to my ride but not sure how I should do. I did some searching on the ground kits and hks earth was a popular one. I won't be buying one off eBay. I'll make it if that's the case.
I just wanted to get some opinions. I'm looking for both engine and audio performance.
Thanks,
-Anthony
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby Solarafreek » Thu Jul 13, 2006 12:48 pm
Solarafreek
Postby SleeperSolara » Fri Jul 14, 2006 7:45 am
You could make your own.......
"StockSolara" had some made.......
Postby SolaraGuy22 » Wed Jan 17, 2007 9:40 pm
Okay... Thread retrieval and last time I'm going to bring it up. I FINALLY have everything I need to make my ground wire kit. But what I don't have is where everything goes.
Since I'm now delayed from installing my CPE this weekend I'm still going to do the ground upgrade.
I'm going to do the whole project Saturday and take my time measuring and heat shrinking and all that. Could someone post exactly which point needs to go to the next point? (since I'm such a noob)
I did some searching of course and found this thread but it didn't really help that much http://www.solaraguy.org/viewtopic.php?t=18657
Also would it be better to chain them together or run them all to the negative battery post?
Thanks for your help everyone,
-Anthony
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby netherland24 » Wed Jan 17, 2007 9:42 pm
i redid all my grounds/ and power wire in my gen 4 camry...
MAKE SURE U leave ur ABS wire too ur alternator stock...
its really simple too do
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby SolaraGuy22 » Wed Jan 17, 2007 9:46 pm
netherland24 wrote:MAKE SURE U leave ur ABS wire too ur alternator stock...
Why is that?
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby netherland24 » Wed Jan 17, 2007 9:51 pm
i had my abs light kick on when i replace it with thick wire... why i dont know.
just was my experiance
00 SS Lara 277hp
netherland24
Postby bassthrive » Wed Jan 17, 2007 10:23 pm
SolaraGuy22 wrote:Okay... Thread retrieval and last time I'm going to bring it up. I FINALLY have everything I need to make my ground wire kit. But what I don't have is where everything goes.
-Anthony
Simply replace along the path of the stock ground wires at their respective locations. I chained my homebrew ground kit, cleanest install IMO. From memory...
START
1. Passenger side of intake plenum / ACIS
2. Short length to chassis by passenger strut mount
3. Short length to engine near the radiator cap
4. Longer run under the engine cover down to the transaxle
5. From transaxle to chassis bolt below airbox / battery tray
6. Finally to negative terminal
END
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
