SolaraGuy.com • View topic - Lexus GS 17" x 8 5 - 114.3 on a Gen 4 Camry V6
Postby camry noob » Fri Feb 21, 2003 7:44 pm
Pls help... will these 17 x 8" wheels fit my Gen 4 Camry V6 and what tire size do you guys recommend? With 8", it would seem tight. My Gen 4 is not lowered at this time. Any suggestions on tires... I saw threads on Toyo/Bridgestone and Kuhmo. What is best for wet weather driving?
FACTORY LEXUS ALLOY WHEELS( 100% GENUINE TOYOTA PARTS): 17X8" , 5 LUGS ON 4-1/2"(114.3mm) ...WILL FIT ON ALL GS300, GS 400,GS430, AND SC300/400 SERIES
camry noob
Postby impactX » Tue Feb 25, 2003 5:04 am
8" is too wide... You'd have better luck with the IS rims.
Web weather driving... Gotta love the Toyo Proxes T1S... I corner in the wet as if I am driving in dry. :D
impactX
Re: Lexus GS 17" x 8 5 - 114.3 on a Gen 4 Camry V6
Postby Flipside909 » Wed Feb 26, 2003 12:02 pm
camry noob wrote:Pls help... will these 17 x 8" wheels fit my Gen 4 Camry V6 and what tire size do you guys recommend? With 8", it would seem tight. My Gen 4 is not lowered at this time. Any suggestions on tires... I saw threads on Toyo/Bridgestone and Kuhmo. What is best for wet weather driving?
Those wheels are specifically made for RWD cars. Notice your Camry is not RWD. Look for another wheel.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby happy_aggies » Thu Feb 27, 2003 9:58 am
I am using 18x8, no problem so far.
So check the offset, it should fit.
happy_aggies
Postby Guest » Thu Mar 13, 2003 7:45 pm
GS rims should have 50mm offset. 8in + 50mm... :(
Guest
Postby Yanks0114 » Thu Mar 13, 2003 8:12 pm
impactX wrote:Web weather driving... Gotta love the Toyo Proxes T1S... I corner in the wet as if I am driving in dry. :D
Just tested out with my new suspension in the rain and I love the toyos so much. They grip the road like no other in rain :D
I'm sure there are better tires out there, but coming from stock tires and snow tires, what a difference
Postby NASTY » Thu Mar 13, 2003 10:20 pm
Yanks0114 wrote:Just tested out with my new suspension in the rain and I love the toyos so much. They grip the road like no other in rain :D
its probably in my head, but i could swear they grip BETTER in wet then they do in dry!!
(already put on the summer wheels? isnt it a little early?)
'01 SLE V6
NASTY
Postby Flipside909 » Thu Mar 13, 2003 11:55 pm
Anonymous wrote:GS rims should have 50mm offset. 8in + 50mm... :(
I believe they are +55 if I recall correctly. All in all, they're the wrong offset and will interfere with the struts in the rear.
www.clublexus.com
Flipside909
Postby Flipside909 » Thu Mar 13, 2003 11:57 pm
Get Yokohama AVS ES100's. Many of my friends have this tire and highly recommend it. This will be my next set after these Kumho's go.
www.clublexus.com
Flipside909
Postby Russian Guy » Fri Mar 14, 2003 12:13 am
Exactly what I planned to buy before decided to order TRD wheels/tiresa =)
1MZ-FE TRD S/C. 2 BLITZ NUR Spec mufflers. SPA Boost/Fuel + Revotec water/oil/volt gauges. BLITZ Powermeter ID III, Denso IK 22 Iridium, TRD brake lines, TRD rear sway bar, fuel pump upgrade
Russian Guy
Postby DavPak » Fri Mar 14, 2003 6:11 am
Flipside909 wrote:Get Yokohama AVS ES100's. Many of my friends have this tire and highly recommend it. This will be my next set after these Kumho's go.
both myself and a friend who has an '89 supra have them and we've both been very pleased with the handling, wear and wet traction. can't wait to put em back on, but only after some of these potholes are gone!
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Yanks0114 » Fri Mar 14, 2003 11:56 am
I don't have that many miles on these tires now, but when they do wear out i'm going to get those or the michelin pilots
Postby Yanks0114 » Fri Mar 14, 2003 11:57 am
NASTY wrote:its probably in my head, but i could swear they grip BETTER in wet then they do in dry!!
LOL, I couldn't wait any longer. My snow tires were also wearing out quickly and I want to be able to get another season out of them
Postby Flipside909 » Sat Mar 15, 2003 1:46 pm
Yeah those are my top two choices for tires right now. Yokohama AVS ES100 or Michelin Pilot Sport A/S. I'm only going to get the Pilot Sport A/S if my income is a little more steady at the time I buy tires again.
www.clublexus.com
Flipside909
Users browsing this forum: Google [Bot] and 51 guests
