SolaraGuy.com • View topic - Sparco Race Pedals?
Sparco Race Pedals?
Sparco Race Pedals?
Postby tboidsc » Thu Jul 27, 2006 9:54 am
Anyone have experience with Sparco Race Pedals. If so, any thoughts on a good one to get. If not Sparco, any other brand. I would rather get a nice set that drill into the base plate, rather than the clip-on kind. Thanx
2000 TRD Solara 5-sp DWP
1MZ-FZE engine
Supercharged, lots of extras
Renova front Grille
tboidsc
Postby steve-o » Thu Jul 27, 2006 10:00 am
Use the Search function at the top of the page.. But since yer from S.I.
Here's a start. I ended up with the OBX's. Make sure the suckers will fit and ther is no obstruction w/ the accelerator before you jump in. Also keep in mind that the size of the pedals are small. So drilling 4 holes or whatever and lining them up w/ the pedal is going to be rough. You could wing it with some high grade double sided adhesive tape..but all installation guides seem to want you to put clips or drill holes along w. the adhesive. Good luck.
http://www.cardomain.com/shoptype/Sport+Pedals
steve-o
Postby tboidsc » Fri Jul 28, 2006 6:19 am
Thanx, I will try more searching, just didn; see any good threads on Sparco pedals. I will also look into OBX, good advice.
1MZ-FZE engine
Renova front Grille
tboidsc
Postby steve-o » Fri Jul 28, 2006 7:43 am
Yeh. Not much info on shift knobs and sport pedals. If you go for the OBX's make sure they will fit. Toyota parts should know. Good luck. Let us know what you end up with.
steve-o
Users browsing this forum: No registered users and 108 guests
